Reverse_proxy wiht unix socket not working
I am trying to reverse proxy a unix socket, but it’s not working.
If I use this commands it works fine, I get the response from the server:
$ curl --unix-socket /tmp/srv.sock http://localhost:8082
$ echo -e "GET / HTTP/1.1\r\nHost: localhost\r\nConnection: close\r\n\r\n" | nc -U /tmp/srv.sock
Response:
HTTP/1.1 200 OK
Content-Type: application/json; charset=utf-8
Date: Fri, 22 Mar 2024 00:36:44 GMT
Content-Length: 46
Connection: close
{"message":"Welcome from inside the go app!"}
Also it work with nginx using this config:
server {
    listen 8082;
    server_name localhost;
    location / {
         proxy_pass http://unix:/tmp/srv.sock;
Mar 22 02:15:03 DESKTOP-1IAIK6Q caddy[133519]: {"level":"debug","ts":1711066503.673956,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"unix//tmp/srv.sock","duration":0.000174006,"request":{"remote_ip":"::1","remote_port":"52862","client_ip":"::1","proto":"HTTP/1.1","method":"GET","host":"localhost:8082","uri":"/","headers":{"Sec-Fetch-Site":["none"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-User":["?1"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Accept-Language":["en-GB,en;q=0.9,en-US;q=0.8"],"Sec-Fetch-Mode":["navigate"],"Cache-Control":["max-age=0"],"Upgrade-Insecure-Requests":["1"],"Sec-Ch-Ua":["\"Chromium\";v=\"122\", \"Not(A:Brand\";v=\"24\", \"Microsoft Edge\";v=\"122\""],"X-Forwarded-For":["::1"],"X-Forwarded-Proto":["http"],"Sec-Ch-Ua-Mobile":["?0"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36 Edg/122.0.0.0"],"X-Forwarded-Host":["localhost:8082"]}},"error":"dial unix /tmp/srv.sock: connect: no such file or directory"}
Mar 22 02:15:03 DESKTOP-1IAIK6Q caddy[133519]: {"level":"error","ts":1711066503.6740086,"logger":"http.log.error.log0","msg":"dial unix /tmp/srv.sock: connect: no such file or directory","request":{"remote_ip":"::1","remote_port":"52862","client_ip":"::1","proto":"HTTP/1.1","method":"GET","host":"localhost:8082","uri":"/","headers":{"Upgrade-Insecure-Requests":["1"],"Sec-Ch-Ua-Mobile":["?0"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36 Edg/122.0.0.0"],"Sec-Fetch-Site":["none"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Dest":["document"],"Connection":["keep-alive"],"Sec-Ch-Ua":["\"Chromium\";v=\"122\", \"Not(A:Brand\";v=\"24\", \"Microsoft Edge\";v=\"122\""],"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["en-GB,en;q=0.9,en-US;q=0.8"],"Cache-Control":["max-age=0"],"Sec-Fetch-User":["?1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Ch-Ua-Platform":["\"Windows\""]}},"duration":0.00034089,"status":502,"err_id":"w5277cjk8","err_trace":"rever
seproxy.statusError (reverseproxy.go:1267)"}
sudo apt update
sudo apt install caddy
Ubuntu 22.04.4 LTS via Windows WSL 2
sudo service caddy start
	root * /usr/share/caddy
	# php_fastcgi localhost:9000
:8082 {
	reverse_proxy unix//tmp/srv.sock
	output file /var/log/caddy/test.log {
		roll_size 100mb
		roll_keep 30
		level DEBUG
		roll_keep_for 720h
That’s because the Caddy service uses PrivateTmp which isolates /tmp for the service, replaced with something like /tmp/systemd-private-<some-hash>-caddy.service-<some-id>/tmp
Try putting your socket file somewhere else like /run which is usually where services put their socket files.
@francislavoie thanks that worked
