Reverse proxy WebTools Plex
I am trying to get Plex WebTools to be working with reverse proxy.
This is what I got so far
   proxy /webtools 192.168.1.5:33400/webtools {
		without /webtools
This is the instructions on the site and my config. Does Caddy not support proxypass and proxypass reverse options? https://i.imgur.com/cwCYfoD.png
The Base URL text box is used to enter the url required if you are using a proxy server. If you do not use a proxy server, then leave this text box blank.
EG: Your base URL may be something like: /WebTools
If using mod_proxy from Apache something like this should do it:
AllowEncodedSlashes NoDecode
ProxyPass /WebTools http://localhost:33400/WebTools nocanon
ProxyPassReverse /WebTools http://localhost:33400/WebTools nocanon```
Solved it was my issue with running multiple plex instances. The configuration above works.
I do have a question. Which approach is the better one?
		without /webtools
Option 2:
	proxy /webtools 192.168.1.5:33400 {
