Reverse-proxy websocket
I am trying to use caddy as reverse-proxy for a FastAPI server. It works otherwise but fails to open websocket connection.
I have spend some days trying all possible hints from web and AI tools. I do not have any deep understanding on the topic.
brython.js:10369 WebSocket connection to 'ws://caddy.local/ws' failed: Establishing a tunnel via proxy server failed
curl -vL caddy.local/slideshow.html
* Uses proxy env variable no_proxy == 'localhost,127.0.0.1,127.0.0.3'
* Uses proxy env variable http_proxy == 'http://127.0.0.1:8000'
*   Trying 127.0.0.1:8000...
* Connected to 127.0.0.1 (127.0.0.1) port 8000
* using HTTP/1.x
> GET http://caddy.local/slideshow.html HTTP/1.1
> Host: caddy.local
> User-Agent: curl/8.12.1
> Proxy-Connection: Keep-Alive
* Request completely sent off
< HTTP/1.1 200 OK
< date: Mon, 31 Mar 2025 17:17:08 GMT
< server: uvicorn
< content-length: 1519
<!DOCTYPE html>
<html lang="fi">
<head>
    <meta charset="utf-8" />
    <meta name="viewport" content="width=device-width, initial-scale=1.0" />
    <link rel="stylesheet" href="/static/styles/album_client.css" />
    <script type="text/javascript" src="static/scripts/brython.js"></script>
    <script type="text/javascript" src="static/scripts/brython_stdlib.js"> </script>
    <title>slideshow</title>
</head>
<body onload="brython()"> <!-- {pythonpath: ['static/scripts/']} -->
<div id='sivu'>
    <div id='valikot'>
        <div id="valikko_0"></div>
        <div id="valikko_1"></div>
        <div id="valikko_2"></div>
        <div id="start"></div>
        <p style="text-align: center; margin: 2em; color: hsla(216, 100%, 10%, 1)">
            <a href="{{ url_for('home', path='/') }}">Home</a></p>
    </div>
    <div id='kehys'>
         <button id="seis" type="button">SEIS</button>
        <img id='photo' src="" alt="kuva"/>
        <video id='video' controls preload="none">
        <video id='video' src='' type="video/mp4" controls preload="none" width="1280" height="720" style="float: right">
        </video>
        <div id='info'>
            <h1 id='otsikko'></h1>
            <div id='kuvaus'></div>
            <p id='ryhma'></p>
            <p id='paivays'></p>
            <p id='n_kuva'></p>
        </div>
        <!--        <div id="nappulat"></div> -->
    </div>
</div>
<script type="text/python" src="static/scripts/slideshow.py"></script>
</body>
</html>
* Connection #0 to host 127.0.0.1 left intact
version v2.9.1
installed with pip
Operating System: openSUSE Tumbleweed 20250329
KDE Plasma Version: 6.3.3
KDE Frameworks Version: 6.12.0
Qt Version: 6.8.2
Kernel Version: 6.13.8-1-default (64-bit)
Graphics Platform: Wayland
Processors: 8 × 11th Gen Intel® Core™ i7-1165G7 @ 2.80GHz
Memory: 62.6 GiB of RAM
Graphics Processor: Intel® Iris® Xe Graphics
Manufacturer: Notebook
Product Name: NS50_70MU
System Version: 2.2A
 sudo caddy run --config Caddyfile
caddy.local  {
reverse_proxy localhost:8000
Your curl seems to be using a forward proxy (127.0.0.1:8000), which sits in front of your Caddy server.
Try this command:
curl --noproxy '*' -vL caddy.local/slideshow.html
to check the result when bypassing 127.0.0.1:8000.
Your other option is to update your system environment variables and add caddy.local to your proxy exception list:
no_proxy='localhost,127.0.0.1,127.0.0.3,caddy.local'
Thank you,
I got a lot further, but as a beginner, I still have some issue. curl-command opens a websocket connection with wss://caddy.local/ws but not with https://caddy.local/ws nor caddy local/ws. caddy.local does not request websocket and works fine.
Caddyfile trial
caddy.local  {
@websockets {
    header Connection *Upgrade*
    header Upgrade websocket
reverse_proxy @websockets http://127.0.0.1:8000
reverse_proxy  http://127.0.0.1:8000
        output file caddy_log.json
        format json
        # level  <level>
server side
@app.websocket("/ws")
async def websocket_endpoint(websocket: WebSocket):
    print('server waiting websocket')
    await websocket.accept()
    print('accepted')
    while True:
Three curl -vL tests
success: curl -vL caddy.local
* Host caddy.local:80 was resolved.
* IPv6: (none)
* IPv4: 127.0.0.3
*   Trying 127.0.0.3:80...
* Connected to caddy.local (127.0.0.3) port 80
* using HTTP/1.x
> GET / HTTP/1.1
> Host: caddy.local
< Connection: close
< Location: https://caddy.local/
< Server: Caddy
< Date: Tue, 01 Apr 2025 10:19:38 GMT
< Content-Length: 0
* shutting down connection #0
* Issue another request to this URL: 'https://caddy.local/'
* Host caddy.local:443 was resolved.
* IPv6: (none)
* IPv4: 127.0.0.3
*   Trying 127.0.0.3:443...
* SSL connection using TLSv1.3 / TLS_AES_128_GCM_SHA256 / x25519 / id-ecPublicKey
* ALPN: server accepted h2
*  subject:
*  start date: Apr  1 05:41:37 2025 GMT
*  expire date: Apr  1 17:41:37 2025 GMT
*  subjectAltName: host "caddy.local" matched cert's "caddy.local"
*  issuer: CN=Caddy Local Authority - ECC Intermediate
*   Certificate level 0: Public key type EC/prime256v1 (256/128 Bits/secBits), signed using ecdsa-with-SHA256
*   Certificate level 1: Public key type EC/prime256v1 (256/128 Bits/secBits), signed using ecdsa-with-SHA256
*   Certificate level 2: Public key type EC/prime256v1 (256/128 Bits/secBits), signed using ecdsa-with-SHA256
* Connected to caddy.local (127.0.0.3) port 443
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://caddy.local/
* [HTTP/2] [1] [:method: GET]
* [HTTP/2] [1] [:authority: caddy.local]
* [HTTP/2] [1] [:path: /]
* [HTTP/2] [1] [user-agent: curl/8.12.1]
* [HTTP/2] [1] [accept: */*]
> GET / HTTP/2
> Host: caddy.local
< HTTP/2 200
< content-type: application/json
< date: Tue, 01 Apr 2025 10:19:38 GMT
< server: Caddy
< server: uvicorn
< content-length: 37
* Connection #1 to host caddy.local left intact
{"message":"Slideshow in /slideshow"}```
FAIL curl -vL caddy.local/ws
* IPv6: (none)
* IPv4: 127.0.0.3
* using HTTP/1.x
> GET /ws HTTP/1.1
> Host: caddy.local
< Connection: close
< Location: https://caddy.local/ws
< Server: Caddy
< Date: Tue, 01 Apr 2025 10:23:36 GMT
< Content-Length: 0
* Issue another request to this URL: 'https://caddy.local/ws'
* IPv6: (none)
* IPv4: 127.0.0.3
*  subject:
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://caddy.local/ws
* [HTTP/2] [1] [:path: /ws]
> GET /ws HTTP/2
> Host: caddy.local
< HTTP/2 404
< date: Tue, 01 Apr 2025 10:23:36 GMT
< server: Caddy
< server: uvicorn
< content-length: 22
{"detail":"Not Found"}
SUCCESS (?) curl -vL wss://caddy.local/ws
* IPv6: (none)
* IPv4: 127.0.0.3
*  subject:
* using HTTP/1.x
> GET /ws HTTP/1.1
> Host: caddy.local
> Upgrade: websocket
> Connection: Upgrade
> Sec-WebSocket-Version: 13
> Sec-WebSocket-Key: MrU33WLxUqqVRKYeqBhiKQ==
< HTTP/1.1 101 Switching Protocols
< Alt-Svc: h3=":443"; ma=2592000
< Connection: Upgrade
< Date: Tue, 01 Apr 2025 10:27:56 GMT
< Sec-WebSocket-Accept: AQjQteJFysFB0hERbbVO8ZYngGY=
< Server: Caddy
< Server: uvicorn
< Upgrade: websocket
* Received 101, switch to WebSocket; mask 78194a98
* WS: auto-respond to PING with a PONG
* WS-ENC: sending [PONG payload=0/4]
* WS-ENC: buffered [PONG payload=4/4]
* WS: flushed 10 bytes
I do not know, where the error was, but now caddy works locally with the following settings
caddy.local  {
    handle /ws {
        reverse_proxy fastapi.local:8000 {
I will test on my production server one of these days.
Thank you
Both of them go to the same port and address. You don’t need the multiple handles. This is more than enough:
caddy.local {
That is true. The other one was just a left-over from my haphazard experimentation.
Quite amazing how little configuration caddy needs.
I had problems to get websocket work and tried all kinds of tricks I found from the internet (there are awfully many different ). All of them useless.
I guess the problem was the proxy running in my computer which I failed to bypass. I set my browser to no-proxy and testing goes nicely.
I can also use linkchecker.
