v2 latest docker version
in compose file: caddy run --config “/etc/caddy/Caddyfile” --adapter “caddyfile”
NAME=“Oracle Linux Server”
VERSION=“8.2”
Client: Docker Engine - Community
Version: 19.03.13
API version: 1.40
sudo -E docker-compose up
version: "3"
image: caddy
container_name: caddy-container
#user:
#privileged:
#environment:
command: caddy run --config "/etc/caddy/Caddyfile" --adapter "caddyfile"
expose:
- "80"
- "443"
#when using sudo, you get https://forums.docker.com/t/docker-compose-not-seeing-environment-variables-on-the-host/11837/7
#So use the -E when starting docker-compose
- ${PWD}/caddy/data:/data
- ${PWD}/caddy/Caddyfile:/etc/caddy/Caddyfile
- ${PWD}/caddy/config:/config
- ${PWD}/caddy/www:/usr/share/caddy
#depends_on:
#networks:
jenkins:
image: jenkinsci/blueocean #uses LTS
container_name: jenkins-container
user: root
privileged: true
#- JAVA_OPTS="-Xmx4096m"
#- JENKINS_HOME=${PWD}/jenkins-data
- DOCKER_HOST=tcp://docker:2376
- DOCKER_CERT_PATH=/certs/client
- DOCKER_TLS_VERIFY=1
#command:
expose:
- "8080"
- "50000"
- "8080:8080"
- "50000:50000"
- ${PWD}/jenkins-data:/var/jenkins_home
- ${PWD}/jenkins-docker-certs:/certs/client:ro
#depends_on:
#networks:
dind:
image: docker:dind
container_name: docker-dind-container
#user:
privileged: true
- DOCKER_TLS_CERTDIR=/certs
#command:
#expose:
- "2376:2376"
#depends_on:
#networks:
# email to use on Let's Encrypt
email @ domain.com
#acme_ca https://acme-staging-v02.api.letsencrypt.org/directory
#debug
#1
#jenkins.domain.com {
#respond "Service currently unavailable"
#reverse_proxy jenkins-container:8080
#2
# reverse_proxy {
# to http://jenkins-container:8080
# health_path /health
# health_status 200
# transport http {
# read_buffer 4096
I’m trying to protect jenkins-container:8080 http://jenkins.domain.com:8080 by reverse-proxy it through caddy https://jenkins.domain.com. But after the setup the internal address is yet accessible to external world.
The first setup (#1) is working, but everyone can hit http://jenkins.domain.com:8080 - shouldn’t it be blocked by default?
The second one (#2) does not work, when I try the https://jenkins.domain.com it give me a blank page and the following error:
jenkins-container | 2020-10-14 17:09:09.664+0000 [id=28] INFO jenkins.InitReactorRunner$1#onAttained: Completed initialization
jenkins-container | 2020-10-14 17:09:09.756+0000 [id=20] INFO hudson.WebAppMain$3#run: Jenkins is fully up and running
caddy-container | {"level":"info","ts":1602695368.9761386,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"unexpected status code","status_code":403,"host":"jenkins-container:8080"}
caddy-container | {"level":"error","ts":1602695378.3320687,"logger":"http.log.error","msg":"no upstreams available","request":{"remote_addr":"10.9.1.111:41566","proto":"HTTP/2.0","method":"GET","host":"jenkins.domain.com","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:78.0) Gecko/20100101 Firefox/78.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8"],"Accept-Language":["pt-BR,pt;q=0.8,en-US;q=0.5,en;q=0.3"],"Accept-Encoding":["gzip, deflate, br"],"Cookie":["_ga=GA1.4.832148051.1581363323; jenkins-timestamper-offset=10800000; screenResolution=1920x1080; JSESSIONID.f7f59b99=node0bwtd7djb4a2ri32b5vmxm0sb20.node0; JSESSIONID.a654ec24=node01it9hlj8laneb16x3sd34sztq20.node0"],"Upgrade-Insecure-Requests":["1"],"Te":["trailers"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"jenkins.domain.com"}},"duration":0.000057614,"status":502,"err_id":"78yy7z56a","err_trace":"reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:440)"}
caddy-container | {"level":"info","ts":1602695398.9765975,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"unexpected status code","status_code":403,"host":"jenkins-container:8080"}
caddy-container | {"level":"info","ts":1602695428.9754827,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"unexpected status code","status_code":403,"host":"jenkins-container:8080"}
caddy-container | {"level":"info","ts":1602695458.9752088,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"unexpected status code","status_code":403,"host":"jenkins-container:8080"}
I can access (http://jenkins.domain.com:8080) normally.
