1. Output of caddy version
2.6.2
Docker
xcaddy build docker 2.6.2 alpine
caddy start
FROM caddy:2.6.2-builder AS builder
RUN xcaddy build \
--with github.com/gamalan/caddy-tlsredis
FROM caddy:2.6.2
RUN mkdir -p /usr/caddy
COPY Caddyfile /etc/caddy
RUN caddy start
on_demand_tls {
interval 2m
burst 5
storage redis {
host "{$SSL_PROXY_REDIS_HOST}"
port {$SSL_PROXY_REDIS_PORT}
address "" // no default, but is build from host+":"+port, if set, then host and port is ignored
username ""
password "{$SSL_PROXY_REDIS_PASSWORD}"
db {$SSL_PROXY_REDIS_DB}
key_prefix "caddytls"
value_prefix "caddy-storage-redis"
timeout 5
tls_enabled "false"
tls_insecure "true"
http:// {
respond /health 200
https:// {
on_demand
reverse_proxy {$SSL_PROXY_UPSTREAM}
edited:
i’m getting a
{"level":"error","ts":1669253345.7200336,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"http2: stream closed"}
error when it attempts to connect to the upstream; this upstream works with nginx and other reverse proxies so i’m a bit stumped . (the upstream is listening on http port 80 and the variable is an http:// address
This error happens immediately upon accessing a page that would make caddy hit the upstream.
{"level":"info","ts":1669253138.9718034,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1669253138.9718316,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
{"level":"info","ts":1669253138.9723413,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1669253138.9723556,"msg":"serving initial configuration"}
Removing and adding transport http; putting the full url in instead of the env variable for the proxy upstream (http://prometheus1.342434.svc.cluster.local)
changing the https:// to https:// / .
From the logs it’s connecting redis fine; requesting certificates fine and just refusing to do anything related to the reverse proxy with no errors and i’m stumped but hoping it’s a simple syntax fubar on my part
