Reverse Proxy to Websocket does not work via HTTPS
I have done this tutorial
The file app.js is configured to
const stompClient = new StompJs.Client({
    brokerURL: '/gs-guide-websocket'
It works, when I call it directly via http://localhost:8080.
It works, when it is reverse proxied via Caddy Server using HTTP without TLS via http://sophienzentrum.org.
It does not work, when it is reverse proxied via Caddy Server using HTTPS with TLS via https://sophienzentrum.org.
stomp.umd.min.js:1 WebSocket connection to 'wss://sophienzentrum.org/gs-guide-websocket' failed
via F12 developer console.
fhurlbrink@suada
OS: Debian GNU/Linux 13 (trixie) x86_64
Host: KVM/QEMU Standard PC (i440FX + PIIX, 1996) (pc-i440fx-6.1)
Kernel: Linux 6.12.48+deb13-amd64
Uptime: 57 mins
Packages: 348 (dpkg)
Shell: bash 5.2.37
Terminal: /dev/pts/0
CPU: AMD EPYC-Milan (2) @ 2.00 GHz
GPU: Red Hat, Inc. QXL paravirtual graphic card
Memory: 457.21 MiB / 1.83 GiB (24%)
Swap: Disabled
Disk (/): 1.23 GiB / 78.54 GiB (2%) - ext4
Local IP (ens6): 87.106.216.175/32
Locale: C.UTF-8
sudo apt install caddy
systemctl reload caddy
sophienzentrum.org:80 {
        reverse_proxy localhost:8080
sophienzentrum.org:443 {
The problem is your backend server, it only accepts the origin header as HTTP
# Works:
curl -v 'wss://sophienzentrum.org/gs-guide-websocket' -H 'Origin: http://sophienzentrum.org'
# Fails:
curl -v 'wss://sophienzentrum.org/gs-guide-websocket' -H 'Origin: https://sophienzentrum.org'
Note that both requests are over WSS, only the latter sends the HTTPS host in the header, while the top one
Your backend server is spring server
You need to allow the origin for the websockets:
    registry.addEndpoint("/gs-guide-websocket").setAllowedOrigins("https://sophienzentrum.org");
Thank you very much! This helped me a lot!
