Pre-emptive: I know, reverse proxying Vercel removes a lot of Vercel’s benefits. I have real-world business reasons for doing this ![]()
I run it as a systemd service using the digital ocean marketplace image.
I update the config through the admin API over ssh (root), and use it to create reverse proxy routes for domains/subdomains.
I use the JSON configuration and don’t use a caddyfile.
Ubuntu 18.04
Systemd caddy-api service
service caddy-api start
(or it’s enabled as a service so it’ll auto start on reboot)
Systemd service file at:
/lib/systemd/system/caddy-api.service
# caddy-api.service
# For using Caddy with its API.
# This unit is "durable" in that it will automatically resume
# the last active configuration if the service is restarted.
ExecStart=/usr/bin/caddy run --environ --resume
"admin": {
"disabled": false,
"listen": "localhost:2019"
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
":80",
":443"
"routes": [
"@id": "vhost_781",
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "reverse_proxy",
"headers": {
"request": {
"set": {
"Host": [
"filesharepage.vercel.app"
"X-Forwarded-Proto": [
"https"
"upstreams": [
"dial": "filesharepage.vercel.app:443"
"match": [
"host": [
"t1.fileshare.page"
"terminal": true
"tls": {
"automation": {
"on_demand": {
"ask": "https://cloud.approximated.app/check-domain"
"logging": {
"logs": {
"default": {
"level": "DEBUG",
"writer": {
"filename": "caddy_api_log_file",
"output": "file"
I’m trying to get a reverse proxy to work with filesharepage.vercel.app as the upstream target.
My problem with proxying to Vercel specifically is that it’s always returning a redirect (either 308 or 304 depending on browser) to filesharepage.vercel.app instead of a regular response.
My DNS for fileshare.page has an A record for *.fileshare.page pointing at my caddy server, so that’s all setup and working (works with other reverse proxies).
I had thought that originally Vercel was redirecting because I wasn’t upstreaming it to port 443, so naturally it was trying to redirect to the https version. I still think that’s happening but I’m not sure why anymore, because I’m sending it to port 443 as you can see in the config.
Is there something wrong with how I’m setting up my route/reverse proxy here?
If not, any idea why Vercel is redirecting (or how it would even know I’m proxying?).
2021/02/22 23:47:59.049 debug http.handlers.reverse_proxy upstream roundtrip
"upstream":"filesharepage.vercel.app:443",
"request":{
"remote_addr":"50.98.241.177:3039",
"proto":"HTTP/2.0",
"method":"GET",
"host":"filesharepage.vercel.app",
"uri":"/",
"headers":{
"Accept":[
"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"
"Sec-Fetch-Mode":[
"navigate"
"Accept-Language":[
"en-US,en;q=0.9"
"Accept-Encoding":[
"gzip, deflate, br"
"X-Forwarded-For":[
"50.98.241.177"
"Referer":[
"https://approximated-carterbryden.codeanyapp.com/"
"Sec-Fetch-Site":[
"cross-site"
"Sec-Fetch-User":[
"?1"
"Cookie":[
"__stripe_mid=77ed7b4d-00b0-4999-8364-04666c6ab1cb7e506c"
"User-Agent":[
"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/88.0.4324.182 Safari/537.36"
"Dnt":[
"1"
"X-Forwarded-Proto":[
"https"
"Upgrade-Insecure-Requests":[
"1"
"Sec-Fetch-Dest":[
"document"
"tls":{
"resumed":false,
"version":772,
"cipher_suite":4865,
"proto":"h2",
"proto_mutual":true,
"server_name":"t1.fileshare.page"
"duration":0.01170214,
"headers":{
"Server":[
"Vercel"
"X-Vercel-Id":[
"sfo1::"
"Strict-Transport-Security":[
"max-age=63072000; includeSubDomains; preload"
"Date":[
"Mon, 22 Feb 2021 23:47:59 GMT"
"Content-Length":[
"168"
"Location":[
"https://filesharepage.vercel.app/"
"Cache-Control":[
"s-maxage=0"
"Content-Type":[
"text/html"
"status":308
I’ve tried setting the request header for Host to the upstream dial address, as well as the matching host address. Basically I’ve swapped around with every combination I could think of for that.
I’ve set the X-Forwarded-Proto to [“https”] as well.
I’ve tried dialing with no port on the end, with :80 on the end, and with :443 on the end.
I’m not sure what else to do here because it seems like a fairly simple reverse proxy should work here, and I’ve likely just misunderstood or used something wrong.
The target upstream: filesharepage.vercel.app
The subdomain I’m trying to get to reverse proxy to it: t1.fileshare.page
They’re both just test pages as I’m working this out, so don’t mind the rick-roll video ![]()
Any help at all will be really appreciated!
