2.4
Caddy API as a systemd service
Ubuntu 20.04
service caddy-api start
N/A
"admin": {
"disabled": false,
"listen": "localhost:2019"
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
":80",
":443"
"routes": [
"handle": [
"encodings": {
"gzip": {}
"handler": "encode"
"handler": "reverse_proxy",
"headers": {
"request": {
"set": {
"Host": [
"s3.test.approximated.app"
"X-Forwarded-Proto": [
"https"
"apx-incoming-host": [
"response": {
"set": {
"apx-hit": [
"true"
"transport": {
"protocol": "http",
"tls": {}
"upstreams": [
"dial": "s3.test.approximated.app.s3-website-us-west-2.amazonaws.com:80"
"match": [
"host": [
"terminal": true,
"@id": "vhost_1012"
"tls": {
"automation": {
"on_demand": {
"ask": "https://mydomain.com/check-domain"
"logging": {
"logs": {
"default": {
"level": "DEBUG"
I’ve setup an S3 bucket static website at:
http://s3.test.approximated.app.s3-website-us-west-2.amazonaws.com/
It’s been setup as a static website, will public read permissions, and even CORS is set to allow any domain. I can load it up in my browser okay, but whenever I try to reverse proxy to it, it times out and caddy says that the context cancelled or EOF.
"level":"error",
"ts":1630361328.6027532,
"logger":"http.log.error",
"msg":"EOF",
"request":{
"remote_addr":"93.187.218.219:57618",
"proto":"HTTP/2.0",
"method":"GET",
"host":"s3.test.approximated.app",
"uri":"/",
"headers":{
"User-Agent":[
"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.159 Safari/537.36"
"Sec-Fetch-Site":[
"none"
"Sec-Ch-Ua":[
"\"Chromium\";v=\"92\", \" Not A;Brand\";v=\"99\", \"Google Chrome\";v=\"92\""
"Cache-Control":[
"max-age=0"
"Dnt":[
"1"
"Upgrade-Insecure-Requests":[
"1"
"Sec-Fetch-Dest":[
"document"
"Sec-Ch-Ua-Mobile":[
"?0"
"Accept-Encoding":[
"gzip, deflate, br"
"Accept-Language":[
"en-US,en;q=0.9"
"Accept":[
"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"
"Sec-Fetch-Mode":[
"navigate"
"Sec-Fetch-User":[
"?1"
"tls":{
"resumed":true,
"version":772,
"cipher_suite":4865,
"proto":"h2",
"proto_mutual":true,
"server_name":"s3.test.approximated.app"
"duration":23.122204434,
"status":502,
"err_id":"ywnvu6yyz",
"err_trace":"reverseproxy.statusError (reverseproxy.go:852)"
"level":"debug",
"ts":1630361504.542603,
"logger":"http.handlers.reverse_proxy",
"msg":"upstream roundtrip",
"upstream":"s3.test.approximated.app.s3-website-us-west-2.amazonaws.com:80",
"request":{
"remote_addr":"93.187.218.219:54548",
"proto":"HTTP/2.0",
"method":"GET",
"host":"s3.test.approximated.app.s3-website-us-west-2.amazonaws.com",
"uri":"/",
"headers":{
"Accept-Encoding":[
"gzip, deflate, br"
"Accept":[
"1"
"X-Forwarded-For":[
"93.187.218.219"
"Cache-Control":[
"max-age=0"
"Sec-Fetch-User":[
"?1"
"Sec-Fetch-Mode":[
"navigate"
"X-Forwarded-Proto":[
"http"
"Apx-Incoming-Host":[
"Sec-Fetch-Site":[
"none"
"Sec-Fetch-Dest":[
"document"
"Accept-Language":[
"en-US,en;q=0.9"
"User-Agent":[
"Sec-Ch-Ua":[
"Dnt":[
"1"
"?0"
"tls":{
"resumed":true,
"version":772,
"proto":"h2",
"duration":2.87797264,
"error":"context canceled"
I’ve tried searching for other Caddy users reverse proxying to S3 static websites but haven’t found much aside from the plugin for it. Ideally I’d like to avoid the plugin because it should be able to reverse proxy to an s3 static website, according to their docs. I’ve found a number of NGINX examples doing so, some of which explicitly set a dns resolver but I’m not sure how to do that on Caddy if it’s possible.
This might be an issue with S3 or AWS and not Caddy, but I thought I’d see if there are any obvious mistakes I’m making.
Thanks very much for your time!
