Reverse proxy to S3 bucket with handle_response for 404s
Ubuntu 20.04.2 LTS on AWS EC2
d. My complete JSON config:
	"apps": {
		"http": {
			"servers": {
				"blahblahblah": {
					"listen": [":443"],
					"routes": [
							"match": [{
								"host": ["blahblahblah.com"]
							"handle": [{
								"handler": "vars",
								"site_id": "ABCDEFG123456"
							"handle": [
									"handler": "vars",
									"bucket_address": "blahblahblah-content.s3-website-us-east-1.amazonaws.com"
									"handler": "encode",
									"encodings": {
										"gzip": {}
									"minimum_length": 0
									"handler": "subroute",
									"routes": [
											"group": "group0",
											"handle": [{
												"handler": "rewrite",
												"uri": "/{http.vars.site_id}{http.request.uri}"
											"handle": [{
												"handler": "reverse_proxy",
												"headers": {
													"request": {
														"set": {
															"Host": ["{http.vars.bucket_address}"]
												"upstreams": [{
													"dial": "{http.vars.bucket_address}:80"
												"handle_response": [{
													"match": {
														"status_code": [404]
													"routes": [{
														"handle": [
																"uri": "/file/html/get?site_id={http.vars.site_id}&path={http.request.orig_uri}"
																"headers": {
																	"request": {
																		"set": {
																			"Host": ["{http.request.orig_uri}"]
																"upstreams": [{
																	"dial": "api.blahblahblah.com:80"
I’m using Caddy as a reverse proxy to an S3 bucket. I use handle_response to call my API to generate a new file for the bucket if the file does not exist. It’s mostly working fine.
My issues are as follows:
  1. I get the following errors whenever there’s a 404 for the bucket:
ERROR|http.handlers.reverse_proxy|reading from backend|{error: http: read on closed response body}|
ERROR|http.handlers.reverse_proxy|aborting with incomplete response|{error: http: read on closed response body}|
Is this something I need to worry about? Anything I can do to muffle those errors?
  1. My upstream dial to api.blahblahblah.com only works with port 80 which I’m assuming is related to my initial dial to the S3 bucket by port 80. How do I dial using port 443?
This is a known issue with handle_response at this time.
Just a warning, the thread is very long winded, but TL;DR:
The handle_response feature was not intended to be used in conjunction with responses that could have a request body, so if the response has a body at all these errors would happen.
It was more meant to be used with responses that would be empty and have special response headers that could be used to instruct the subsequent routes how to rehandle the request (like X-Accel-Redirect for example, as shown in the docs).
Some additional work will need to be done to make it work properly in situations where a response body is returned.
I think it’s because of the Host header you’re setting. That’ll mess up HTTPS proxying if it doesn’t match what the upstream espects. Also, you need to turn on the transport > http > tls option to tell Caddy to use TLS (setting tls to an empty object {} is sufficient to enable TLS).
Thanks Francis!
Should I not be using handle_response with a reverse_proxy in this manner? Is there a better way?
"handle": [
		"transport": {
			"protocol": "http",
			"tls": {}
		"upstreams": [{
			"dial": "api.blahblahblah.com:443"
Does this not look right? I get a 400 error: “The plain HTTP request was sent to HTTPS port”.
Right now, unfortunately no. It’s not currently a supported usecase of handle_response, but it might be later once that github issue is resolved. I don’t have an alternative for you at this time.
You’re missing a line to set the Host header. It might look like this:
                  "headers": {
                    "request": {
                      "set": {
                        "Host": [
                          "{http.reverse_proxy.upstream.hostport}"
                  "transport": {
                    "protocol": "http",
                    "tls": {}
                  "upstreams": [
                      "dial": "example.com:443"
That placeholder will set the Host header to api.blahblahblah.com:443, i.e. the upstream hostport.
Thanks Francis- I tried that, but no change, I still get the “400 Bad Request - The plain HTTP request was sent to HTTPS port” error.
Make sure to reload your Caddy config after changing it.
The only thing I can think of is that – you haven’t properly reloaded your config. The config I posted is definitely correct.
I reloaded, but no dice. :^)
	"apps": {
		"http": {
			"servers": {
				"testsite": {
					"listen": [":443"],
					"routes": [
							"match": [{
								"host": ["example.com"]
							"handle": [{
								"handler": "vars",
								"site_id": "5ace6cb611704a7fbd849075"
							"handle": [
									"handler": "vars",
									"bucket_address": "mybucket-content.s3-website-us-east-1.amazonaws.com"
									"encodings": {
										"gzip": {}
									"minimum_length": 0
									"routes": [
											"group": "group0",
											"handle": [{
											"handle": [{
												"headers": {
													"request": {
														"set": {
												"upstreams": [{
													"match": {
													"routes": [{
														"handle": [
																"headers": {
												                    "request": {
												                      "set": {
												                        "Host": [
																"transport": {
												                    "protocol": "http",
												                    "tls": {}
																"upstreams": [{
																	"dial": "api.samplesite.com:443"
