Reverse proxy to multiple backends using request header as key
Installed via apt, and uses systemd.
Ubuntu 20.04 Linux.
proxy1.hooli.xyz {
    reverse_proxy https://google.com {
        lb_policy header backend-google
        header_down -server
    reverse_proxy https://yahoo.com {
        lb_policy header backend-yahoo
        header_down -server
    reverse_proxy https://espn.com {
        lb_policy header backend-espn
        header_down -server
    respond 404
I am trying to reverse proxy to 3 different backends switching on a request header. For example if the header is backend-espn proxy to https://espn.com. If the header is not passed, or does not match a header key I am looking to return a 404 error.
Right now, it just returns 404 for all requests even when passing a valid header.
curl -i https://proxy1.hooli.xyz -H "backend-yahoo: true"
HTTP/2 404
server: Caddy
content-length: 0
date: Wed, 16 Feb 2022 19:47:18 GMT
You want to use request matchers here, not lb_policy.
lb_policy is for load balancing, i.e. choosing between multiple backends configured on a single reverse_proxy handler.
That said, I think what you’re really looking for here is a forward-proxy, not a reverse-proxy. Proxying to google and such isn’t really what you should be doing with a reverse-proxy.
@francislavoie thanks for the reply. I just put google.com, yahoo.com, and espn.com as examples. The reverse proxy backends are gonna be private endpoints like 10.0.0.2:1455.
I updated my Caddyfile to the following, but still not working correctly.
proxy1.hooli.xyz {
    @google {
        header Proxy-Backend google
    @yahoo {
        header Proxy-Backend yahoo
    @espn {
        header Proxy-Backend espn
    reverse_proxy @google https://google.com {
        header_down -server
    reverse_proxy @yahoo https://yahoo.com {
        header_down -server
    reverse_proxy @espn https://espn.com {
        header_down -server
    respond 404
This should be proxying to Yahoo.com.
curl -i https://proxy1.hooli.xyz -H "Proxy-Backend: yahoo"
HTTP/2 404
server: Caddy
content-length: 0
date: Thu, 17 Feb 2022 01:01:33 GMT
The problem now is that directives are sorted according to a predetermined order, so respond 404 happens before all the reverse_proxy directives.
You can use handle blocks to set up mutually exclusive routing. For example:
proxy1.hooli.xyz {
	@google header Proxy-Backend google
	handle @google {
	# Fallback if no other "handle" matches
		respond 404
Thanks. I got this working. For others interested my full Caddyfile is:
proxy1.hooli.xyz {
    @google {
        header ReverseProxy-Upstream google
    @yahoo {
        header ReverseProxy-Upstream yahoo
    @espn {
        header ReverseProxy-Upstream espn
    handle @google {
            header_down -server
    handle @yahoo {
            header_down -server
    handle @espn {
            header_down -server
         respond "reverse proxy upstream not found" 404 {
             close
Good job. For the record, I think you could probably tidy up that config even more with the map directive:
