Reverse proxy to localhost on VPS without opening ports
1. Output of caddy version:
v2.6.2
sudo caddy start
Debian 11
Paste command here.
Paste your config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
I am trying to reverse proxy from a subdomain to an application running on a certain port.
In the past I had my applications running on docker and everything was fine. But docker regularly rewrites IP_tables and I want to have control over my firewall rules, since I am using a VPS, where every exposed port is directly exposed to the internet.
Unfortunately the reverse proxy to localhost is not working with ufw blocking anything incoming except 80 and 443. I always get a ‘connection refused’ error, unless I expose the port I am forwarding to.
How do I best configure Caddy to avoid exposing ports?
So Caddy is running as systemd service on your host (Debian 11) and UFW is only allowing :80 and :443.
The connection from your client (e.g. web browser) to Caddy is fine, I’d assume?
Is your reverse_proxy target (upstream) you are trying to proxy to running in Docker or rather directly on that host like Caddy itself?
It used to run in Docker, which was fine. But since Docker rewrites IP-tables, I cannot be sure that this isn’t because the port is exposed.
Now I am trying to run the target on the same host as Caddy as another systemd service. This throws the connection refused error.
Can you please share the output of
curl --verbose --location localhost:8080
or whatever target port you are using
