1. Caddy version: 2.6.2
Installed as Docker container on Unraid
Unraid linux server
Running Nextcloud as another container by linuxserver.io. Both containers are on a private docker network so they can communicate via hostnames.
Starts automatically via Unraid
cloud.[redacted].com {
reverse_proxy https://nextcloud:443 {
tls_insecure_skip_verify
I have multiple local servers working great behind caddy using as reverse proxy. I’m having an issue getting Nextcloud to work without using the tls_insecure_skip_verify above which I’m reading is both not recommended and may even be removed eventually. I’m having trouble understanding how to properly use https locally.
I have the caddy IP as a trusted proxy in the nextcloud config and the tls_insecure_skip_verify line in the Caddy file
I tried following this but I didn’t know how to get the ACME server setup and I couldn’t follow it exactly since it sounds like he has the caddy server on a dedicated machine/VM instead of in Docker. Not sure if this is the only way to really do it.
Edit: Reading further into that link it looks like he is using the tls_insecure_skip_verify for nextcloud as well.
