Reverse proxy to HTTPS on local network (to my Synology NAS)
I am trying to configure the reverse proxy for my https://nas.trescak.com to point to the admin url of my NAS which runs on https://192.168.1.200:5001
I have other services I would like configure that run on https ports as well.
This is the error from the log
Jan 15 20:38:10 tomi-beast caddy[2310]: {"level":"error","ts":1705311490.5540106,"logger":"http.log.error","msg":"tls: failed to verify certificate: x509: cannot validate certificate for 192.168.1.200 because it doesn't contain any IP SANs","request":{"remote_ip":"192.168.1.1","remote_port":"54956","client_ip":"192.168.1.1","proto":"HTTP/3.0","method":"GET","host":"nas.trescak.com","uri":"/","headers":{"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"Cookie":[],"Sec-Fetch-Site":["none"],"Sec-Fetch-Mode":["navigate"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.1 Safari/605.1.15"],"Accept-Language":["en-AU,en;q=0.9"],"Sec-Fetch-Dest":["document"],"Accept-Encoding":["gzip, deflate, br"],"Priority":["u=0, i"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h3","server_name":"nas.trescak.com"}},"duration":0.003145431,"status":502,"err_id":"186cu44km","err_trace":"reverseproxy.statusError (reverseproxy.go:1267)"}
Linux Ubuntu 20.x
Nothing, default install running from the caddy.service
# caddy.service
# for your installation.
Type=notify
jobiq.com.au, www.jobiq.com.au {
        reverse_proxy :3020
credit.trescak.com {
        reverse_proxy :3010
nas.trescak.com {
        reverse_proxy https://192.168.1.200:5001
tel.trescak.com {
        reverse_proxy :3030
I found the answer here:
