So I set up a small container on Proxmox to use as a reverse proxy. Basically I just want to proxy all requests to all of my web services through this one server. I think (??) Caddy is supposed to be able to do this. Problem is, I can’t get it to proxy almost anything, and can’t figure out why some configurations work and others don’t.
I am sure I’m missing something obvious / doing something stupid because I’m new to this, but I have no idea what.
I’ll start simple. I have a PiHole DNS server. If I want to proxy requests to the server, my Caddyfile looks like this.
mydomain.net
proxy / 192.168.2.0/admin {
That actually works perfectly fine. It brings up the page normally. However, if I change it to this:
mydomain.net
proxy /pihole 192.168.2.0/admin {
Doesn’t work anymore. Instead of the admin page I get some generic text as if it’s not loading everything properly. If I remove the transparent option here, it looks to load up the background and text from the pihole root home page, but doesn’t load the images.
So I discovered that I need to add the “without” directive. Went ahead and did that and now this one works.
mydomain.net
without /pihole
Same situation with my simple dokuwiki. However, in this case, “without” does not work. The dokuwiki will load only if it is proxied from the root of the domain.
mydomain.net
proxy /wiki 192.168.2.2 {
without /wiki
This gives me a 404, although the browser does appear to be trying to load mydomain.net/doku.php
Then I have some that just don’t work at all. For instance, if I try to proxy to my Proxmox webGUI at all, I just get 502, regardless of whether I proxy from root or a sub-directory. Proxmox I believe auto-fowards everything to https so I’m not sure if that’s a problem or not, and it also runs on an unusual port, but I tried specifying both in the config. It just 502s regardless.
mydomain.net
proxy / https://192.168.2.1:8006 {
Would appreciate any insight into what I’m doing wrong here.
