Reverse proxy + tls client_auth depending on path
I want to reverse_proxy somewhere. Depending on the path I’d like to either require no client authentication or mtls / client_auth - e.g. for /admin/*.
I dont need authentication towards the backend.
Error: adapting config using caddyfile: parsing caddyfile tokens for 'handle': directive 'tls' is not an ordered HTTP handler, so it cannot be used here - try placing within a route block or using the order global option
When I try with route {}:
Error: adapting config using caddyfile: parsing caddyfile tokens for 'route': tls directive returned something other than an HTTP route or subroute: &caddytls.InternalIssuer{CA:"", Lifetime:0, SignWithRoot:false, ca:(*caddypki.CA)(nil), logger:(*zap.Logger)(nil)} (only handler directives can be used in routes), at /etc/caddy/Caddyfile:241
v2.7.6
xcaddy AFAIR
Debian 11, linux 5.10.0-27-armmp
# systemd unit:
Type=notify
domain.tld {
        import errors # handle_errors {}
        handle /admin/* {
                import mtls_conf
                reverse_proxy 192.168.xxx:80
        import log_conf # log {}
        import tls_conf # tls foo@bar.tld {  on_demand }
(mtls_conf) {
    tls internal {
        client_auth {
            mode require_and_verify
            trusted_ca_cert_file /etc/caddy/ca-cert-bundle.crt
It’s impossible to configure client_auth based on request path, because the TLS handshake happens before HTTP is event sent down the wire, so the server has no idea what the request path is until after TLS is agreed upon.
Use subdomains instead. Domains are passed via TLS-SNI during the handshake, so you can configure Caddy to have different TLS config per subdomain.
As the error tells you, the tls directive is not an HTTP handler directive, it cannot go within handle, it must go top-level within a site block.
