Grizzle33
(Josh Grizzle)
January 18, 2018, 4:25am
#1
Hello.
I have had success setting up reverse proxy’s for guacamole and Ombi and I was wanting to get one set up for Subsonic.
My current config looks like this - very basic.
mydomain.com {
gzip
proxy / 192.168.1.226:4040 {
I have tried several different iterations of the file with no real success.
I am able to type the url in my local brower and it pulls the site up, however it displays the local ip address instead of the URL and HTTPS like it does with guac and ombi.
Any help is greatly appreciated. Thank you.
Hi @Grizzle33 , welcome to the Caddy community.
The fact that your browser is displaying the IP address after you navigate to mydomain.com
is interesting. Perhaps subsonic is redirecting canonically?
Is the site otherwise functional, apart from the URL showing the IP?
Could you post the output of curl -iL mydomain.com
(substituting your real domain, of course).
Grizzle33
(Josh Grizzle)
January 18, 2018, 5:17pm
#3
Here’s the output from curl. After this display, it shows all the HTML of the site.
HTTP/1.1 301 Moved Permanently
Connection: close
Server: Caddy
Date: Thu, 18 Jan 2018 17:13:18 GMT
Content-Length: 63
Content-Type: text/html; charset=utf-8
HTTP/1.1 302 Found
Content-Length: 0
Expires: Thu, 01 Jan 1970 00:00:00 GMT
Location: http://192.168.1.226:4040/login.view;jsessionid=nyuwu1yyib9i ?
Server: Caddy
Server: Jetty(6.1.x)
Set-Cookie: JSESSIONID=nyuwu1yyib9i;Path=/
HTTP/1.1 200 OK
Content-Language: en
Content-Length: 5795
For the record - i’m a total rookie. I’m sure the answer is glaring at me.
Grizzle33:
Must be issuing its session redirect using the Host
header rather than a relative link?
Try
which will forward the Host (music.domain.com
?) to the Jetty server, hopefully it picks up on that.
Grizzle33
(Josh Grizzle)
January 19, 2018, 9:16pm
#5
Thank you this worked perfectly!
system
(system)
closed
April 19, 2018, 9:16pm
#6
