Reverse Proxy Storj GatewayST
I’m new to caddy. I’m trying reverse proxy GatewayST (They forked MinIO as far as I can remember, I’m not sure) which is running on port 7777.
The problem is I’m getting following error if I open an object url.
400 Bad Request: malformed Host header.
OS : Ubuntu 22.04
Using : Systemd
cdn.nixorigin.one {
  reverse_proxy /nixone/* 127.0.0.1:7777 {
    header_up X-Real-IP {remote}
    header_up X-Forwarded-For {remote}
    header_up Host {http.host}
The issue has been resolved after removing
Remove all of these. Caddy sets these headers automatically to the appropriate values. See reverse_proxy (Caddyfile directive) — Caddy Documentation
Thanks for the heads up !
