Reverse Proxy Standards - What else can I do?
Hello there,
after try a couple of RPs my way leads me to caddy.
At the moment I’m running v2.8.4 on a Raspi 4 to send all tld-requests to a lil Proxmox-Server and a Synology-Server. As you can see, my tld goes trough cloudflare. And as I want all subs getting ssl.
A basicauth is also running and works.
Here my question(s):
What else can I do to make it “better”, faster and saver? What have I add to get loadbalacing and other stuff that make my config better? Hope you understand what I want.
Yes, I could read many many Wikis and stuff, but it’s overloaded and I didn’t understand everything correctly. English, as you guess, isn’t my native language. And I’m old. Just need some “add this to your config and you’re good”-stuff.
:443   {
    tls internal {
        on_demand
    root * /usr/share/caddy
(cloudflare) {
                dns cloudflare thisismycloudflareapi
home.example.com {
        basicauth {
           user $2a$thatworktoo
        reverse_proxy 192.168.0.0:port
            protocols tls1.3
sub.example.com {
            protocols tls1.3
Of course this aren’t all subs, but their all looking the same as the example above.
Thank you in advance for not roasting and helping.
Dan
Are you sure you need this? This is insecure and unsafe if your server is publicly accessible, because then any attacker could point unlimited domains to your server and cause your server to fill up with garbage certs and keys until you run out of storage space. This serves no purpose, so remove it. You should not use on_demand unless you understand the implications. and read all the warnings on the tin (the docs).
Remove this. There’s no reason to override the TLS protocols Caddy uses. Let Caddy choose modern secure defaults for you.
Next time, please fill out the help topic template as per the forum rules.
I’m not sure of course. I will remove it.
And I will remove the protocols.
Everything else? Load balancing, or?
You only have one upstream, so load balancing isn’t a thing. That would matter if you had more than one copy of the upstreams.
Seems like this is for a home server? Don’t worry about it.
Yes, it’s a home server. Thank you very much.
Other than things Francis already mentioned, your config honestly looks good!
With Caddy, simpler is almost always better. The less config you have, the faster the server will be. Caddy cares a lot about having modern, secure, fast defaults out of the box, so you only need to configure exceptions to the best practice, if you really need them.
Caddy is fastest and safest with just a single reverse_proxy in a site block.
Nice to hear. It’s really confusing of that easy setup.
