2.4.5
docker (compose) on debian buster.
We build a Caddy with the following Dockerfile:
FROM caddy:2.4.5-builder-alpine AS builder
RUN xcaddy build \
--with github.com/caddy-dns/lego-deprecated \
--with github.com/kirsch33/realip \
--with github.com/caddyserver/format-encoder
FROM caddy:2.4.5-alpine
ENV GCE_PROJECT=ctd-sandbox
docker-compose up -d caddy
version: "3"
image: gcr.io/ctorg/caddy
- "0.0.0.0:80:80"
- "0.0.0.0:443:443"
restart: always
network_mode: bridge
- GCE_PROJECT
- VGS_IPS
- caddy_data:/data
- caddy_config:/config
- ./certificates:/data/caddy/pvtcerts
logging:
driver: gcplogs
caddy_data:
driver: local
driver_opts:
o: bind
type: none
device: /mnt/vpn_data/caddy/data
caddy_config:
driver: local
driver_opts:
o: bind
type: none
device: /mnt/vpn_data/caddy/config
# acme_ca https://acme-v02.api.letsencrypt.org/directory
email meh@blah.com
vpn.{$GCE_PROJECT}.com {
@vpn {
host vpn.{$GCE_PROJECT}.com
reverse_proxy @vpn pritunl:9700
vgs-in.console.{$GCE_PROJECT}.com {
client_auth {
mode require_and_verify
trusted_leaf_cert_file /data/caddy/pvtcerts/{$GCE_PROJECT}/vgs-client.crt
trusted_ca_cert_file /data/caddy/pvtcerts/{$GCE_PROJECT}/myorg-ca.crt
@vgs {
host vgs-in.console.{$GCE_PROJECT}.com
remote_ip {$VGS_IPS:127.0.0.1}
#log {
# format formatted "{ts} {request>headers}"
uri @vgs strip_prefix https://{http.request.hostport}
reverse_proxy @vgs http://console-lb.{$GCE_PROJECT}.com {
versions 1.1
compression off
3. The problem Iâm having:
When I made requests to our site with curl, I see requests reach Caddy and then progress on to our upstream correctly. A tcpdump from the container shows Caddy making the requests correctly setting the proper HOST header, etc etc.
When a request comes in from our partners, these requests get into Caddy just fine (cert verification succeeds, etc). After this point, when Caddy sends these on to the upstream - they just get mangled completely and a tcpdump of this traffic does decode properly to ascii. I donât even see Caddy setting the proper request headers etc when sending this to our upstream. In fact, only the ip and port make sense in the tcpdump. This request is promptly rejected by the upstream as a bad request.
I didnât see a way to log the reverse proxy request headers and body to see why Caddy is making requests that donât make sense.
Here are the Caddy log messages showing the bad requests:
{"level":"debug","ts":1635301164.1388586,"logger":"tls.handshake","msg":"choosing certificate","identifier":"vgs-in.console.ctd.com","num_choices":1}
{"level":"debug","ts":1635301164.139989,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"vgs-in.console.ctd.com","subjects":["vgs-in.console.ctd.com"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"89f51e003367a44460f61370d7a3bea4fb02e949d3f9f4bde318f49b8ff3cfc9"}
{"level":"debug","ts":1635301164.1404738,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["vgs-in.console.ctd.com"],"managed":true,"expiration":1639104921,"hash":"89f51e003367a44460f61370d7a3bea4fb02e949d3f9f4bde318f49b8ff3cfc9"}
{"level":"debug","ts":1635301164.2852256,"logger":"http.handlers.rewrite","msg":"rewrote request","request":{"remote_addr":"34.14.28.15:38109","proto":"HTTP/1.1","method":"POST","host":"vgs-in.console.ctd.com:443","uri":"https://vgs-in.console.ctd.com:443/api/v1/console/connected-integrations/","headers":{"X-Forwarded-Host":["vgs.console.ctd.com"],"Via":["terminator","1.1 reverse-proxy-01-659d7775fb-jqn9k"],"X-B3-Sampled":["1"],"Accept":["*/*"],"Content-Type":["application/json"],"X-Real-Ip":["76.126.248.198"],"X-Forwarded-For":["76.126.248.198, 52.7.148.215"],"Content-Length":["100"],"B3":["6521731aba110191b89273ed7c53256d-f425f8bf50a47bbd-1"],"Vgs-Request-Id":["6521731aba110191b89273ed7c53256d"],"X-B3-Traceid":["6521731aba110191b89273ed7c53256d"],"X-B3-Spanid":["2bd0fe88b6a040f3"],"User-Agent":["curl/7.79.1"],"Vgs-Tenant":["tntirtsalns"],"X-Forwarded-Port":["443"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":771,"cipher_suite":49195,"proto":"","proto_mutual":true,"server_name":"vgs-in.console.ctd.com","client_common_name":"vgs-client","client_serial":"415904724679373504317541964934275127265629157207"}},"method":"POST","uri":"/api/v1/console/connected-integrations/"}
{"level":"debug","ts":1635301164.3453803,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"console-lb.ctd.com:80","request":{"remote_addr":"34.14.28.15:38109","proto":"HTTP/1.1","method":"POST","host":"vgs-in.console.ctd.com:443","uri":"/api/v1/console/connected-integrations/","headers":{"User-Agent":["curl/7.79.1"],"Vgs-Tenant":["tntirtsalns"],"X-Forwarded-Port":["443"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["vgs.console.ctd.com"],"Via":["terminator","1.1 reverse-proxy-01-659d7775fb-jqn9k"],"X-B3-Sampled":["1"],"Content-Length":["100"],"Accept":["*/*"],"Content-Type":["application/json"],"X-Real-Ip":["76.126.248.198"],"X-Forwarded-For":["76.126.248.198, 52.7.148.215, 134.14.28.15"],"X-B3-Spanid":["2bd0fe88b6a040f3"],"B3":["6521731aba110191b89273ed7c53256d-f425f8bf50a47bbd-1"],"Vgs-Request-Id":["6521731aba110191b89273ed7c53256d"],"X-B3-Traceid":["6521731aba110191b89273ed7c53256d"]},"tls":{"resumed":false,"version":771,"cipher_suite":49195,"proto":"","proto_mutual":true,"server_name":"vgs-in.console.ctd.com","client_common_name":"vgs-client","client_serial":"415904724679373504317541964934275127265629157207"}},"duration":0.05931753,"error":"tls: first record does not look like a TLS handshake"}
{"level":"error","ts":1635301164.346308,"logger":"http.log.error","msg":"tls: first record does not look like a TLS handshake","request":{"remote_addr":"134.14.28.15:38109","proto":"HTTP/1.1","method":"POST","host":"vgs-in.console.ctd.com:443","uri":"https://vgs-in.console.ctd.com:443/api/v1/console/connected-integrations/","headers":{"X-Forwarded-Host":["vgs.console.ctd.com"],"Via":["terminator","1.1 reverse-proxy-01-659d7775fb-jqn9k"],"X-B3-Sampled":["1"],"Accept":["*/*"],"Content-Type":["application/json"],"X-Real-Ip":["76.126.248.198"],"X-Forwarded-For":["76.126.248.198, 52.7.148.215"],"Content-Length":["100"],"B3":["6521731aba110191b89273ed7c53256d-f425f8bf50a47bbd-1"],"Vgs-Request-Id":["6521731aba110191b89273ed7c53256d"],"X-B3-Traceid":["6521731aba110191b89273ed7c53256d"],"X-B3-Spanid":["2bd0fe88b6a040f3"],"User-Agent":["curl/7.79.1"],"Vgs-Tenant":["tntirtsalns"],"X-Forwarded-Port":["443"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":771,"cipher_suite":49195,"proto":"","proto_mutual":true,"server_name":"vgs-in.console.ctd.com","client_common_name":"vgs-client","client_serial":"415904724679373504317541964934275127265629157207"}},"duration":0.061101323,"status":502,"err_id":"evr97v2eb","err_trace":"reverseproxy.statusError (reverseproxy.go:858)"}
The upstream logs werenât helpful here - the requests are basically reject as being garbage. I can provide a tcpdump capture file, but that doesnât show anything - no request headers etc⌠It just looks like random binary data.
The one message that seems to stand out from Caddy logs is âtls: first record does not look like a TLS handshakeâ - which doesnât make sense since both Caddy logs and the remote side seem to think that a https connection was established just fineâŚ
I am at a loss as to how Caddy is making an upstream request without setting any proper request headers etc - and how this garbled upstream request is being generated.
