v2.3.0
I run Caddy as a reverse proxy for internal network use via Docker/Docker Compose
Ubuntu v18.04.5, Docker v20.10.3, Docker Compose v1.25.0
docker-compose up -d
version: "3.7"
image: caddy
- ./.caddy/Caddyfile:/etc/caddy/Caddyfile
- caddy-config:/config
- caddy-data:/data
- 443:443
- reverse-proxy
caddy-config:
caddy-data:
reverse-proxy:
http://transmission.fantasio.local {
reverse_proxy transmission:9091
http://transmission2.fantasio.local {
reverse_proxy transmission2:9091
I have 2 Docker containers with names transmission and transmission2 both exposing their web UI on port 9091. When both containers are running everything works, http://transmission.fantasio.local points to transmission and http://transmission2.fantasio.local points to transmission2.
However, if I stop transmission, http://transmission.fantasio.local will start showing transmission2 instead. Can anyone tell me what could be happening here? When transmission is stopped I want http://transmission.fantasio.local to show error.
