I am trying to get the first project to work on Caddy.
I am able to successfully issue this command.
caddy reverse-proxy --from localhost:8080 --to localhost:8000
The next step is to try this using Caddyfile.
This is my Caddyfile:
localhost:8080
reverse_proxy / {
to localhost:8000
health_path /health
health_status 200
read_buffer 4096
I then run the commands:
caddy adapt --config ./Caddyfile
to get the JSON format.
&& finally run
caddy start --config ./Mycaddy
on the JSON.
I am getting this error ERROR http.log.error no upstreams available
Somehow I think that my Caddyfile is wrong.
Is this the right approach on V2?
