Reverse proxy not working for Sonarr
v2.2.0 h1:sMUFqTbVIRlmA8NkFnNt9l7s0e+0gw+7GPIrhty905A=
Use the caddy exe in a local directory. Config file in same directory.
Windows 10
caddy start
NA
cruizer.asus.com {
		output file access.log {
        		roll_size 5MiB
        		roll_keep_for 168h
        		roll_keep 2
	reverse_proxy /sonarr {
		to localhost:8989
I’m trying to use caddy as a reverse proxy for my Sonarr, Radarr services on the same machine. Will concentrate on Sonarr since I think I’m a little closer to getting it to work with caddy.
When I go to cruizer.asus.com/sonarr I get a 400 (HTTP Error 400. The request hostname is invalid.)
2020/10/13 01:05:34.827 error http.log.access.log0 handled request {“request”: {“remote_addr”: “192.168.1.1:51364”, “proto”: “HTTP/2.0”, “method”: “GET”, “host”: “cruizer.asus.com”, “uri”: “/sonarr”, “headers”: {“Accept-Encoding”: [“gzip, deflate, br”], “Dnt”: [“1”], “Upgrade-Insecure-Requests”: [“1”], “Te”: [“trailers”], “User-Agent”: [“Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:81.0) Gecko/20100101 Firefox/81.0”], “Accept”: [“text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,/;q=0.8”], “Accept-Language”: [“en-US,en;q=0.5”]}, “tls”: {“resumed”: false, “version”: 772, “cipher_suite”: 4865, “proto”: “h2”, “proto_mutual”: true, “server_name”: “cruizer.asus.com”}}, “common_log”: “192.168.1.1 - - [13/Oct/2020:14:05:34 +1300] "GET /sonarr HTTP/2.0" 400 334”, “duration”: 0.0009976, “size”: 334, “status”: 400, “resp_headers”: {“Server”: [“Caddy”, “Microsoft-HTTPAPI/2.0”], “Content-Length”: [“334”], “Content-Type”: [“text/html; charset=us-ascii”], “Date”: [“Tue, 13 Oct 2020 01:05:34 GMT”]}}
Rechecked port forwards on the router (443 to the box for TCP and UDP to be sure)
Tried various caddyfile configurations e.g. tried a trailing / on /sonarr/
Connecting to domain root gives me a blank page, I’m guessing the error is coming from Sonarr but not sure how to verify that.
I’ve done extensive research online to try and find an answer but most configurations I’m coming across are the same as mine.
Sonarr configured for /sonarr URL base
Tried this config:
cruizer.asus.com
respond "test"
It works :+1:
I’ve spent about 3 hours on this so far with no luck :blush:
Thanks for your help!
Path matching is exact-match in Caddy v2 (/sonarr will only match exactly /sonarr but not /sonarr/foo), so you need to append a * to the end to match any subpath.
The HTTP 400 status is likely because sonarr is expecting the host to be something else. There must be some way to configure that.
That said, I typically recommend serving apps like Sonarr on subdomains rather than subpaths, for these reasons:
Thanks fransiclavoie. On your first bit, it certainly appears that Sonarr is expecting the host to be something it’s not. Weird that in hours of Googling I haven’t found another person with the issue.
What I change my caddyfile to be
localhost
reverse_proxy localhost:8989
it works perfectly
And
localhost
reverse_proxy /sonarr localhost:8989
Gives me everything you described in the subfolder problem article you linked to :laughing:
I think you can try this (as described in the subfolder article):
handle_path /sonarr* {
This should work as long as sonarr properly uses relative paths for HTML links. If it doesn’t, you may need to configure it to change the base path, if possible.
Like I said though, using a subdomain would avoid any issues altogether, with something like this:
sonarr.example.com
I’m still not getting past the 400 with that config unfortunately.
Well at this point, it’s not an issue with Caddy, and it’s an issue with Sonarr config. Sonarr is returning that error, not Caddy.
Yes it seems that way. Thanks for your help Francis.
For anyone else that comes across this, I managed to sort it out by running Sonarr as admin once to register all hostnames on the 8989 port. Also needed to declare the path as
reverse_proxy /sonarr* localhost:8989
as Sonarr returns everything with the trailing forward slash.
