Reverse proxy not working as expected. 1
Currently, the reverse proxy appears to be working, however when I put in the address. All I get is a white screen, no content. No errors.
Currently, it is just designed to push this: https://hellmanx.ddns.net/homeassistant to my home assistant server.
curl https://hellmanx.ddns.net/homeassistnat -vL
* Expire in 0 ms for 6 (transfer 0xb2b950)
* Expire in 1 ms for 1 (transfer 0xb2b950)
* Expire in 0 ms for 1 (transfer 0xb2b950)
* Expire in 2 ms for 1 (transfer 0xb2b950)
* Expire in 4 ms for 1 (transfer 0xb2b950)
* Expire in 3 ms for 1 (transfer 0xb2b950)
*   Trying 73.214.218.190...
* TCP_NODELAY set
* Expire in 200 ms for 4 (transfer 0xb2b950)
* Connected to hellmanx.ddns.net (73.214.218.190) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*   CAfile: none
  CApath: /etc/ssl/certs
* SSL connection using TLSv1.3 / TLS_CHACHA20_POLY1305_SHA256
*  subject: CN=hellmanx.ddns.net
*  start date: Jul 11 18:20:06 2023 GMT
*  expire date: Oct  9 18:20:05 2023 GMT
*  subjectAltName: host "hellmanx.ddns.net" matched cert's "hellmanx.ddns.net"
* Using Stream ID: 1 (easy handle 0xb2b950)
> GET /homeassistnat HTTP/2
> Host: hellmanx.ddns.net
> User-Agent: curl/7.64.0
< HTTP/2 200
< server: Caddy
< content-length: 0
< date: Tue, 11 Jul 2023 19:37:45 GMT
* Connection #0 to host hellmanx.ddns.net left intact
Installed using Caddy App Templates on Portainer.io.
Raspberry Pi4 | Debian 10.
Portainer
CMD, according to portainer:
Image: caddy:latest@sha256:39597db44e2e53317349a9e42e7719ea893dd04e623b644d70f2b31f630366da
hellmanx.ddns.net:443 {
        handle_path /homeassistant/* {
		reverse_proxy https://10.0.0.13:8123
The matcher /homeassistant/* doesn’t match /homeassistant because there’s no trailing slash. Try /homeassistant* instead.
That’ll cause a 502 error.
This is what the dockers log shows when that 502 error happens:
2023-07-12T00:05:55.994970520Z ERR ts=1689120355.994555 logger=http.log.error msg=tls: first record does not look like a TLS handshake request={“remote_ip”:“174.203.106.15”,“remote_port”:“6973”,“proto”:“HTTP/2.0”,“method”:“GET”,“host”:“hellmanx.ddns.net”,“uri”:“/homeassistant”,“headers”:{“Sec-Ch-Ua-Mobile”:[“?1”],“Sec-Fetch-Site”:[“none”],“Sec-Fetch-Dest”:[“document”],“Accept-Language”:[“en-US,en;q=0.9”],“Cache-Control”:[“max-age=0”],“Sec-Ch-Ua”:[“"Not.A/Brand";v="8", "Chromium";v="114", "Google Chrome";v="114"”],“User-Agent”:[“Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Mobile Safari/537.36”],“Accept”:[“text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,/;q=0.8,application/signed-exchange;v=b3;q=0.7”],“Sec-Fetch-Mode”:[“navigate”],“Sec-Fetch-User”:[“?1”],“Accept-Encoding”:[“gzip, deflate, br”],“Sec-Ch-Ua-Platform”:[“"Android"”],“Upgrade-Insecure-Requests”:[“1”]},“tls”:{“resumed”:false,“version”:772,“cipher_suite”:4867,“proto”:“h2”,“server_name”:“hellmanx.ddns.net”}} duration=0.019860413 status=502 err_id=v2n5jew57 err_trace=reverseproxy.statusError (reverseproxy.go:1299)
You configured your proxy with https://. Are you sure it’s an HTTPS upstream? Remove that if it’s an HTTP upstream.
Hmm, good point. Looks like It’s just using HTTP, could’ve sworn it was HTTPs.
There’s an error on the browser now: 400: Bad Request
Portainer doesn’t seem to be throwing any errors in the live log when I get the 400 error.
That’s coming from your app, not Caddy. Either way, nothing we can do to help without more details.
I was actually able to get closer to a solution with this config:
        handle_path /homeassistant* {
		reverse_proxy http://10.0.0.13:8123
But I was only able to get a picture of the Home Assistant logo, nothing else.
I also learned that Home Assistant has some type of reverse proxy whitelist too, so I may have to ask that community about why I’m only getting a Home Assistant logo and no login afterwards.
See this article:
Running services under subpaths often won’t work. You can use a subdomain instead like home.hellmanx.ddns.net.
Yeah, I learned that Home Assistant does not work with subfolders.
I got it to work now.
