@francislavoie
curl -vL https://www.treblemart.com/
* Trying 172.67.135.183:443...
* Connected to www.treblemart.com (172.67.135.183) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CApath: /etc/ssl/certs
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Supplemental data (23):
* TLSv1.2 (OUT), TLS header, Finished (20):
* TLSv1.2 (OUT), TLS header, Supplemental data (23):
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* subject: CN=treblemart.com
* start date: Jul 12 08:04:36 2023 GMT
* expire date: Oct 10 08:04:35 2023 GMT
* subjectAltName: host "www.treblemart.com" matched cert's "*.treblemart.com"
* issuer: C=US; O=Let's Encrypt; CN=E1
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x560d7f2fd560)
> GET / HTTP/2
> Host: www.treblemart.com
> user-agent: curl/7.81.0
> accept: */*
* old SSL session ID is stale, removing
* Connection state changed (MAX_CONCURRENT_STREAMS == 256)!
< HTTP/2 200
< date: Tue, 25 Jul 2023 13:00:41 GMT
< content-length: 0
< alt-svc: h3=":443"; ma=86400
< cf-cache-status: DYNAMIC
< report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=cZY692ejZmVmcQRmD0PZaOrR44nd%2B5GIw5rcXwf%2BXtIRgdbv34L8ln%2Fw253xTPFXbnm3bD6L2uDwbnhoLY0dmk%2FBHlw9OaufhYdyLC1Dwnb9W65e9Sw1fdzGi2mGdpvi1YCs2rQ%3D"}],"group":"cf-nel","max_age":604800}
< nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
< server: cloudflare
< cf-ray: 7ec496551f283657-FRA
* Connection #0 to host www.treblemart.com left intact
Main Caddy logs
Starting caddy ... done
Attaching to caddy
caddy | {"level":"info","ts":1690290423.1389744,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy | {"level":"warn","ts":1690290423.1411724,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":6}
caddy | {"level":"info","ts":1690290423.1432507,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
caddy | {"level":"info","ts":1690290423.1436274,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
caddy | {"level":"info","ts":1690290423.1436522,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy | {"level":"info","ts":1690290423.1441505,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
caddy | {"level":"info","ts":1690290423.1442451,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
caddy | {"level":"debug","ts":1690290423.1443558,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
caddy | {"level":"info","ts":1690290423.144372,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
caddy | {"level":"debug","ts":1690290423.1444337,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
caddy | {"level":"info","ts":1690290423.1444488,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
caddy | {"level":"info","ts":1690290423.1444528,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["admin.treblemart.com","www.treblemart.com"]}
caddy | {"level":"debug","ts":1690290423.1450722,"logger":"tls","msg":"loading managed certificate","domain":"admin.treblemart.com","expiration":1697359935,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/data/caddy"}
caddy | {"level":"debug","ts":1690290423.1455386,"logger":"tls.cache","msg":"added certificate to cache","subjects":["admin.treblemart.com"],"expiration":1697359935,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"5ce14ca8c0a4ee74427a6d1de25982b718fab4e932beea5847560e8c92030cf8","cache_size":1,"cache_capacity":10000}
caddy | {"level":"debug","ts":1690290423.1456046,"logger":"events","msg":"event","name":"cached_managed_cert","id":"4d197154-e664-4bb4-8ff6-1e01b8e47e3b","origin":"tls","data":{"sans":["admin.treblemart.com"]}}
caddy | {"level":"debug","ts":1690290423.1461003,"logger":"tls","msg":"loading managed certificate","domain":"www.treblemart.com","expiration":1697359509,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/data/caddy"}
caddy | {"level":"debug","ts":1690290423.146513,"logger":"tls.cache","msg":"added certificate to cache","subjects":["www.treblemart.com"],"expiration":1697359509,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"b0b49f8883177eb86e845ce5353f77fd58962bb0faaefd693b76cf71e4785d2b","cache_size":2,"cache_capacity":10000}
caddy | {"level":"debug","ts":1690290423.1465464,"logger":"events","msg":"event","name":"cached_managed_cert","id":"36241da3-bd1d-4cd9-90d4-7f035758408d","origin":"tls","data":{"sans":["www.treblemart.com"]}}
caddy | {"level":"info","ts":1690290423.1470122,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0004e42a0"}
caddy | {"level":"info","ts":1690290423.1471553,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
caddy | {"level":"info","ts":1690290423.1472306,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy | {"level":"info","ts":1690290423.147546,"msg":"serving initial configuration"}
caddy | {"level":"info","ts":1690290423.148306,"logger":"tls","msg":"finished cleaning storage units"}
caddy | {"level":"debug","ts":1690290468.4882154,"logger":"events","msg":"event","name":"tls_get_certificate","id":"d2c4882f-f707-4fd2-ab26-06de4e7cf449","origin":"tls","data":{"client_hello":{"CipherSuites":[4865,4866,4867,49195,49196,49199,49200,49171,49192,156,157,47,53,10],"ServerName":"www.treblemart.com","SupportedCurves":[29,23,24,25],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537,513,1539],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771,770,769],"Conn":{}}}}
caddy | {"level":"debug","ts":1690290468.4883835,"logger":"tls.handshake","msg":"choosing certificate","identifier":"www.treblemart.com","num_choices":1}
caddy | {"level":"debug","ts":1690290468.4884007,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"www.treblemart.com","subjects":["www.treblemart.com"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"b0b49f8883177eb86e845ce5353f77fd58962bb0faaefd693b76cf71e4785d2b"}
caddy | {"level":"debug","ts":1690290468.4884088,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"172.69.150.199","remote_port":"38246","subjects":["www.treblemart.com"],"managed":true,"expiration":1697359509,"hash":"b0b49f8883177eb86e845ce5353f77fd58962bb0faaefd693b76cf71e4785d2b"}
caddy | {"level":"debug","ts":1690290468.6231728,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"treble-ecommerce-variant-products-frontend:80","total_upstreams":1}
caddy | {"level":"debug","ts":1690290468.6249497,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"treble-ecommerce-variant-products-frontend:80","duration":0.001672164,"request":{"remote_ip":"172.69.150.199","remote_port":"38246","proto":"HTTP/2.0","method":"GET","host":"www.treblemart.com","uri":"/","headers":{"Cf-Ray":["7ec4a0c2bf774dc0-FRA"],"User-Agent":["curl/7.81.0"],"X-Forwarded-Proto":["https"],"Cf-Ipcountry":["IN"],"X-Forwarded-For":["172.69.150.199"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Cf-Connecting-Ip":["157.245.110.30"],"Accept-Encoding":["gzip"],"Accept":["*/*"],"Cdn-Loop":["cloudflare"],"X-Forwarded-Host":["www.treblemart.com"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"www.treblemart.com"}},"headers":{"Server":["Caddy"],"Date":["Tue, 25 Jul 2023 13:07:48 GMT"],"Content-Length":["0"]},"status":200}
Frontend caddy log
treble-ecommerce-variant-products-frontend_1 |
"level": "info",
"ts": 1690290468.62473,
"logger": "http.log.access",
"msg": "handled request",
"request": {
"remote_ip": "172.18.0.5",
"remote_port": "46384",
"proto": "HTTP/1.1",
"method": "GET",
"host": "www.treblemart.com",
"uri": "/",
"headers": {
"Accept": [
"Accept-Encoding": [
"gzip"
"X-Forwarded-For": [
"172.69.150.199"
"Cf-Ray": [
"Cf-Visitor": [
"X-Forwarded-Host": [
"X-Forwarded-Proto": [
"https"
"User-Agent": [
"curl/7.81.0"
"Cdn-Loop": [
"cloudflare"
"Cf-Connecting-Ip": [
"157.245.110.30"
"Cf-Ipcountry": [
"IN"
"user_id": "",
"duration": 0.00000336,
"size": 0,
"status": 0,
"resp_headers": {
"Server": [
"Caddy"
