Ubuntu 20.04 with systemd. Hosts many websites including Flarum
Ubuntu 20.04 on systemd
sudo service caddy start
No clue where the systemd file is
admin off
(logging) {
output file /var/log/caddy/caddy.log {
roll_size 1gb
roll_keep 5
(errors) {
handle_errors {
root * /var/www/internal/errors
rewrite * /{http.error.status_code}.html
(php) {
php_fastcgi unix//run/php/php8.0-fpm.sock
www.telesphoreo.me {
import logging
redir https://telesphoreo.me{uri}
telesphoreo.me {
import logging
import errors
import php
root * /var/www/telesphoreo.me
file_server browse
encode gzip zstd
respond /assets/ 403
respond /files/ 403
respond /files/theme/ 403
respond /files/theme/fonts/ 403
respond /files/theme/images/ 403
respond /uploads/2/6/3/9/26395298/ 403
respond /uploads/2/6/3/9/26395298/background-images/ 403
respond /nitrogen/ 403
respond /wave/ 403
db.telesphoreo.me {
import logging
import php
root * /usr/share/phpmyadmin
i.telesphoreo.me {
import logging
import errors
root * /var/www/i.telesphoreo.me
forum.telesphoreo.me {
import logging
import php
root * /var/www/forum.telesphoreo.me/public
header /assets {
+Cache-Control "public, must-revalidate, proxy-revalidate"
+Cache-Control "max-age=25000"
Pragma "public"
panel.telesphoreo.me {
import logging
import php
root * /var/www/pterodactyl/public
header X-Content-Type-Options nosniff
header X-XSS-Protection "1; mode=block"
header X-Robots-Tag none
header Content-Security-Policy "frame-ancestors 'self'"
header X-Frame-Options DENY
header Referrer-Policy same-origin
request_body {
max_size 100m
respond /.ht* 403
stevennl2000.telesphoreo.me {
import logging
import php
root * /var/www/snl2000.telesphoreo.me/public
header /assets {
Pragma "public"
stevennl2000.telesphoreo.me:28966 {
reverse_proxy http://stevennl2000.telesphoreo.me:28900 {
header_up Host {host}
header_up X-Real-IP {remote}
header_up X-Forwarded-For {remote}
header_up X-Forwarded-Port {server_port}
updater.telesphoreo.me {
import logging
import errors
root * /var/www/updater.telesphoreo.me
file_server browse
wiki.stevennl2000.telesphoreo.me {
import logging
import errors
import php
root * /var/www/wiki.telesphoreo.me
wiki.telesphoreo.me {
import logging
import errors
import php
root * /var/www/tfwiki.telesphoreo.me
packs.smokes-crystal.rocks {
import logging
redir https://i.telesphoreo.me{uri}
www.smokes-crystal.rocks {
import logging
redir https://smokes-crystal.rocks{uri}
import logging
import errors
root * /var/www/smokes-crystal.rocks
So basically I have a Minecraft server that uses NanoHTTPD as a small server. It runs on port 28900. It displays some statistics about the server and pulls files to view. Here’s the thing. Seeing certain things like player punishments is restricted to admins. The way it’s checked is if the admins IP is being used, it will display the page. However, if the IP the user is coming from is not an admin, it will deny them access. The problem is this: “You may not view the punishment list. Your IP, 65.21.153.247, is not registered to an admin on the server.”
This is the IP of the server, not the user IP. It’s not passing the user IP to the server when reverse proxied. I tried adding all the headers back. The way it’s getting the IP is from the default java.net.Socket (socket.getInetAddress().getHostAddress();
). I’m not sure what the best way to go is about fixing it. I tried adding all the headers. Looking at the headers, it says it returned 404 and the headers don’t seem to be different for https://stevennl2000.telesphoreo.me:28900/punishments and https://stevennl2000.telesphoreo.me:28966.
* Trying 65.21.153.247...
* TCP_NODELAY set
* Connected to stevennl2000.telesphoreo.me (65.21.153.247) port 28966 (#0)
* schannel: SSL/TLS connection with stevennl2000.telesphoreo.me port 28966 (step 1/3)
* schannel: checking server certificate revocation
* schannel: sending initial handshake data: sending 192 bytes...
* schannel: sent initial handshake data: sent 192 bytes
* schannel: SSL/TLS connection with stevennl2000.telesphoreo.me port 28966 (step 2/3)
* schannel: failed to receive handshake, need more data
* schannel: encrypted data got 4096
* schannel: encrypted data buffer: offset 4096 length 4096
* schannel: encrypted data length: 180
* schannel: encrypted data buffer: offset 180 length 4096
* schannel: received incomplete message, need more data
* schannel: encrypted data got 465
* schannel: encrypted data buffer: offset 645 length 4096
* schannel: sending next handshake data: sending 93 bytes...
* schannel: encrypted data got 195
* schannel: encrypted data buffer: offset 195 length 4096
* schannel: SSL/TLS handshake complete
* schannel: SSL/TLS connection with stevennl2000.telesphoreo.me port 28966 (step 3/3)
* schannel: stored credential handle in session cache
> GET /punishments HTTP/1.1
> Host: stevennl2000.telesphoreo.me:28966
> User-Agent: curl/7.55.1
* schannel: client wants to read 102400 bytes
* schannel: encdata_buffer resized 103424
* schannel: encrypted data buffer: offset 0 length 103424
* schannel: encrypted data got 260
* schannel: encrypted data buffer: offset 260 length 103424
* schannel: decrypted data length: 231
* schannel: decrypted data added: 231
* schannel: decrypted data cached: offset 231 length 102400
* schannel: decrypted data buffer: offset 231 length 102400
* schannel: schannel_recv cleanup
* schannel: decrypted data returned 231
* schannel: decrypted data buffer: offset 0 length 102400
< HTTP/1.1 404 Not Found
< Content-Length: 106
< Content-Type: text/plain
< Date: Sun, 27 Jun 2021 22:15:59 GMT
< Server: Caddy
You may not view the punishment list. Your IP, 65.21.153.247, is not registered to an admin on the server.* Connection #0 to host stevennl2000.telesphoreo.me left intact
I tried looking at previous solutions. One person added all the headers that Caddy doesn’t keep when reverse proxying. This didn’t work. The only other thing I can think of is to add a special header and have the code check the special header for the Host IP. I know that it’s possible for the host IP to exist as I’ve seen it when (accidently) setting it as a response header. The request headers for the headers don’t appear to be there when I check it from Inspect > Network > Headers though. Not sure what I’m doing wrong?
http://stevennl2000.telesphoreo.me:28900/index
https://stevennl2000.telesphoreo.me:28900/index
