Reverse Proxy Mime Type Issue
v2.0.0-rc.3 h1:z2H/QnaRscip6aZJxwTbghu3zhC88Vo8l/K57WUce4Q=
Ubuntu 18.04, Systemd
As a reverse proxy for many devices on my LAN
sudo systemctl start caddy
# caddy.service
# for your installation.
After=network.target
https://skyview.millhousen.com/ {
	reverse_proxy 192.168.0.151:80
https://wx.millhousen.com/ {
        reverse_proxy 192.168.0.180:80
https://wx.millhousen.com:9001 {
        reverse_proxy 192.168.0.15:9001
https://jellyfin.kstr.us/ {
    reverse_proxy docker.stier.network:8096 {
		tls_insecure_skip_verify
https://spdtst.me {
	reverse_proxy 192.168.0.55:80
#:8080 {
#	forwardproxy
I am working on moving from Caddy 1. The upgrade guide was very helpful! The only thing it didn’t mention was the change in basicauth.
Most of the reverse proxies are not functioning properly.
SPDTST.ME works fine.
The Skyview site looks strange (appears to lack CSS)
The WX site has CSS errors
Jellyfin throws a 502 error
Apr 26 00:25:58 caddy caddy[11064]: {"level":"error","ts":1587875158.9507868,"logger":"http.log.error","msg":"tls: first record does not look like a TLS handshake","request":{"method":"GET","uri":"/","proto":"HTTP/2.0","remote_addr":"192.168.0.1:55640","host":"jellyfin.kstr.us","headers":{"Accept-Language":["en-US,en;q=0.9"],"Upgrade-Insecure-Requests":["1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-Site":["cross-site"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"Accept-Encoding":["gzip, deflate, br"],"Cache-Control":["max-age=0"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.163 Safari/537.36"],"Sec-Fetch-Dest":["document"]},"tls":{"resumed":false,"version":772,"ciphersuite":4865,"proto":"h2","proto_mutual":true,"server_name":"jellyfin.kstr.us"}},"status":502,"err_id":"iak7qgifw","err_trace":"reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:362)"}
CSS-less WX site
(Twitter and Google Analytics errors are DNS blocked, thus normal)
Skyview Site Error
Screenshot from 2020-04-25 23-56-31
I tried taking the encode directive out of one of the sites, but this did not return any different results.
I also tried accessing these domains from outside of my local network, this does not return different results either.
These sites aren’t super important, so I am going to let them run while broken. If you need to check HTTP headers, go right ahead.
Could you share what your working Caddyfile looked like in v1?
Caddy 1 Caddyfile
	proxy / 192.168.0.151:80
	gzip
	tls webmaster@flexstart.me {
		key_type rsa4096
		protocols tls1.0 tls1.2
		must_staple
        proxy / 192.168.0.180:80
        gzip
                key_type rsa4096
                must_staple
        proxy / 192.168.0.15:9001 {
        proxy /mqtt http://192.168.0.15:9001 {
                websocket
        proxy / docker.stier.network:8096 {
                websocket
        gzip
                key_type rsa4096
                must_staple
https://spdtst.me {
	proxy / 192.168.0.55:80
:8080 {
	forwardproxy
CSS errors: The reverse proxy just transports the headers from upstream to downstream. If the backend isn’t sending a Content-Type header (or the wrong value for one), then the backend should probably be fixed. (You can manipulate headers in the proxy config, however – I just don’t recommend this solution.) What server is running on the backend?
Jellyfin errors: You haven’t enabled TLS on your transport. Add a tls subdirective next to tls_insecure_skip_verify. (Hmm, maybe we should do that implicitly. I’ll make a note of that for the future.)
I added the tls subdirective to the Jellyfin config to no avail
The WX site has always been solid as a rock. The backend is actually Caddy 1 on a Raspberry Pi 4. Accessed locally (http://192.168.0.180), it was served without CSS as well because I think the software (weewx) hardcodes the domain into some of the links to stylesheets.
I think I need to start smaller maybe and switch the WX site on the Pi to Caddy 2 (because its config is very very simple). I tried, but I ended up just getting a blank page with no files being served.
I posted that information in another topic to keep this one relevant.
The WX site is now on Caddy 2 :partying_face:
The reverse proxy relaying the site outside my network is not working.
The MIME type error appears to be happening because the only thing it is proxying is the root (https://wx.millhousen.com/). If I add the page name or the name of any other file that it should be proxying (like /index.html, /current.jpg) I get blank 200 replies.
Since a lot has changed I guess, can you clarify what your current config is now, what is not working, and how we can reproduce it? (A curl command would be ideal; no docker, if possible)
The only URL being proxied is the root directory.
The root is served properly
mt-dev@quiet-powerhouse ~> curl -v https://wx.millhousen.com/
*   Trying 216.8.220.80:443...
* Connected to wx.millhousen.com (216.8.220.80) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: none
*  subject: CN=wx.millhousen.com
*  start date: Apr 26 02:33:51 2020 GMT
*  expire date: Jul 25 02:33:51 2020 GMT
*  subjectAltName: host "wx.millhousen.com" matched cert's "wx.millhousen.com"
*  issuer: C=US; O=Let's Encrypt; CN=Let's Encrypt Authority X3
* Using Stream ID: 1 (easy handle 0x5591909a38b0)
> GET / HTTP/2
> Host: wx.millhousen.com
> user-agent: curl/7.69.1
> accept: */*
< HTTP/2 200
< accept-ranges: bytes
< date: Sun, 26 Apr 2020 19:12:52 GMT
< etag: "q9et9bq4s"
< last-modified: Sun, 26 Apr 2020 19:10:23 GMT
< server: Caddy
< server: Caddy
< content-length: 33868
<!DOCTYPE html>
<!-- Page Content -->
</html>
* Connection #0 to host wx.millhousen.com left intact
Nothing else is served (blank output for style.css, index.html, etc)
mt-dev@quiet-powerhouse ~> curl -v https://wx.millhousen.com/style.css
* ALPN, offering h2
  CApath: none
* Using Stream ID: 1 (easy handle 0x56183e0d98b0)
> GET /style.css HTTP/2
> accept: */*
< HTTP/2 200
< server: Caddy
< content-length: 0
< date: Sun, 26 Apr 2020 19:16:51 GMT
Ahh, I bet that’s because your site address is:
Which results in a host matcher for wx.millhousen.com (:white_check_mark:) and a path matcher for / (:no_entry:). Path matchers are exact in Caddy 2, so either remove that slash or add a * after it to make it a prefix match. (But just remove it, why over-complicate things?)
