Reverse Proxy lost port
Hi everyone,
I’m having an issue that I cannot understand whats happening.
I’m trying to setup a reverse proxy in front of an Exchange (owa) .
This is my config (192.168.1.1 is the reverse proxy addres, and 192.168.2.1 is the OWA address)
When I access http://192.168.1.1:10000 The port dissapears from the URL and I can’t continue.
This is product of the Exchange or Caddy ? Maybe something related to http headers ?
Thanks a lot !
2024/04/25 15:15:31.014 error   http.log.access.log0    handled request {"request": {"remote_ip": "192.168.4.179", "remote_port": "35214", "client_ip": "192.168.4.179", "proto": "HTTP/1.1", "method": "GET", "host": "192.168.1.1:10000", "uri": "/", "headers": {"Connection": ["keep-alive"], "Upgrade-Insecure-Requests": ["1"], "User-Agent": ["Mozilla/5.0 (Windows NT 10.0; rv:78.0) Gecko/20100101 Firefox/78.0"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8"], "Accept-Language": ["en-US,en;q=0.5"], "Accept-Encoding": ["gzip, deflate"], "Dnt": ["1"]}}, "bytes_read": 0, "user_id": "", "duration": 3.024855797, "size": 0, "status": 502, "resp_headers": {"Server": ["Caddy"]}}
2024/04/25 15:15:34.060 error   http.log.access.log0    handled request {"request": {"remote_ip": "192.168.4.179", "remote_port": "35214", "client_ip": "192.168.4.179", "proto": "HTTP/1.1", "method": "GET", "host": "192.168.1.1:10000", "uri": "/favicon.ico", "headers": {"User-Agent": ["Mozilla/5.0 (Windows NT 10.0; rv:78.0) Gecko/20100101 Firefox/78.0"], "Accept": ["image/webp,*/*"], "Accept-Language": ["en-US,en;q=0.5"], "Accept-Encoding": ["gzip, deflate"], "Referer": ["http://192.168.1.1:10000/"], "Dnt": ["1"], "Connection": ["keep-alive"]}}, "bytes_read": 0, "user_id": "", "duration": 3.002424585, "size": 0, "status": 502, "resp_headers": {"Server": ["Caddy"]}}
2024/04/25 15:16:23.444 info    http.log.access.log0    handled request {"request": {"remote_ip": "192.168.4.179", "remote_port": "35216", "client_ip": "192.168.4.179", "proto": "HTTP/1.1", "method": "GET", "host": "192.168.1.1:10000", "uri": "/", "headers": {"User-Agent": ["Mozilla/5.0 (Windows NT 10.0; rv:78.0) Gecko/20100101 Firefox/78.0"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8"], "Accept-Language": ["en-US,en;q=0.5"], "Accept-Encoding": ["gzip, deflate"], "Dnt": ["1"], "Connection": ["keep-alive"], "Upgrade-Insecure-Requests": ["1"]}}, "bytes_read": 0, "user_id": "", "duration": 0.00447551, "size": 0, "status": 302, "resp_headers": {"X-Feserver": ["EX2016-MBS"], "Server": ["Caddy", "Microsoft-IIS/10.0"], "X-Requestid": ["34ef725f-9089-4db5-aad5-4456866cd4b7"], "Date": ["Thu, 25 Apr 2024 15:16:23 GMT"], "Content-Length": ["0"], "Cache-Control": ["no-cache"], "Pragma": ["no-cache"], "Location": ["https://192.168.1.1/owa/"]}}
/caddy version
uname -a
Linux srv 5.10.0-15-amd64 #1 SMP Debian 5.10.120-1 (2022-06-09) x86_64 GNU/Linux
cat /etc/debian_version (its devuan)
11.1
./caddy run
Don't have. Running on a VM
http://192.168.1.1:10000 {
                output file caddy.log
        reverse_proxy {
                to https://192.168.2.1:443
                header_up Host Host {http.reverse_proxy.upstream.host}
                        tls
                        tls_insecure_skip_verify
I’m so sorry I didn’t realize the template.
You can edit the post to conform to it. People will not help unless you do so
Looks like your webservice sends a redirect to https://192.168.1.1/owa/
As @Forza said, it sounds like your upstream app is serving a redirect. You’ll need to investigate why it tries to redirect.
Seems weird to me that you have Caddy serve HTTP and then you proxy over HTTPS. Typically Caddy is used to terminate TLS, then proxy over HTTP to some unprotected service.
Honestly I didn´t do the test, just was testing caddy and learning.
But thanks for the comment I’m going to try that.
