I’m attempting to set up a reverse proxy to an https host. If allow http access on the server then the address resolves without issue.
If I disallow http access (the default and how I’d prefer to keep it) I get an HTTP 502 error. I also see a ‘ls: failed to verify certificate: x509: certificate signed by unknown authority’ error in the logs.
If I uncomment tls_insecure_skip_verify, then the cert error goes away but I get an HTTP 302 error instead.
Just to try, I tried turning auto_https off or disabling certs and I get a TLS Alert, internal error (592)
Output with http access allowed on the smx.lymeinternal.net server. (I apologise for the logs as journalctl -u caddy --no-pager | less +G` shows no entries, a separate problem)
curl -vL https://smx.lymeaccess.net:3445
* Host smx.lymeaccess.net:3445 was resolved.
* IPv6: (none)
* IPv4: 198.55.232.56
* Trying 198.55.232.56:3445...
* Connected to smx.lymeaccess.net (198.55.232.56) port 3445
* CApath: /etc/ssl/certs
* SSL connection using TLSv1.3 / TLS_AES_128_GCM_SHA256 / X25519 / id-ecPublicKey
* ALPN: server accepted h2
* subject: CN=smx.lymeaccess.net
* start date: May 9 18:32:59 2025 GMT
* expire date: Aug 7 18:32:58 2025 GMT
* subjectAltName: host "smx.lymeaccess.net" matched cert's "smx.lymeaccess.net"
* issuer: C=US; O=Let's Encrypt; CN=E6
* SSL certificate verify ok.
* Certificate level 0: Public key type EC/prime256v1 (256/128 Bits/secBits), signed using ecdsa-with-SHA384
* Certificate level 1: Public key type EC/secp384r1 (384/192 Bits/secBits), signed using sha256WithRSAEncryption
* Certificate level 2: Public key type RSA (4096/152 Bits/secBits), signed using sha256WithRSAEncryption
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://smx.lymeaccess.net:3445/
* [HTTP/2] [1] [:method: GET]
* [HTTP/2] [1] [:authority: smx.lymeaccess.net:3445]
* [HTTP/2] [1] [:path: /]
* [HTTP/2] [1] [user-agent: curl/8.5.0]
* [HTTP/2] [1] [accept: */*]
> GET / HTTP/2
> Host: smx.lymeaccess.net:3445
> User-Agent: curl/8.5.0
< HTTP/2 200
< access-control-allow-origin: *
< alt-svc: h3=":3445"; ma=2592000
< content-security-policy: default-src 'self' data: https://blue.calix.com; script-src 'self' 'unsafe-inline' 'unsafe-eval' data: https://blue.calix.com; connect-src * 'self' data: https://blue.calix.com; img-src data: 'self' https://blue.calix.com; style-src 'self' 'unsafe-inline' data: https://blue.calix.com;
< date: Thu, 22 May 2025 17:03:52 GMT
< p3p: CP="IDC DSP COR ADM DEVi TAIi PSA PSD IVAi IVDi CONi HIS OUR IND CNT"
< vary: Accept-Encoding
< via: 1.1 Caddy
< x-frame-options: DENY
<!DOCTYPE html>
<html>
<head>
<script id='meteor-headers' type='application/ejson'>{"token":1747933432280.0332,"headers":{"accept-encoding":"gzip","x-forwarded-proto":"https","x-forwarded-host":"smx.lymeaccess.net:3445","x-forwarded-for":"10.0.1.12","via":"2.0 Caddy","accept":"*/*","host":"smx.lymeaccess.net:3445","connection":"close","x-ip-chain":"10.0.1.12,127.0.0.1"}}</script>
<meta http-equiv="X-UA-Compatible" content="IE=10">
<div style="text-align:center;position:absolute;left:40%;top:50%" id="initialSmxPageloading"><div class="lds-default"><div></div><div></div><div></div><div></div><div></div><div></div><div></div><div></div><div></div><div></div><div></div><div></div></div> <span style="font-size:14px;font-weight:bold">Loading please wait...</span></div>
<link rel="stylesheet" type="text/css" class="__meteor-css__" href="/04b06726eaad8387d88a32980b7b2c20d6d2712a.css?meteor_css_resource=true">
<meta charset="utf-8">
<title>SMx</title>
<meta name="description" content="">
<meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no">
<link rel="shortcut icon" href="/images/activate/activate-logo.png" />
<!--link rel="apple-touch-icon" href="img/splash/sptouch-icon-iphone.png">
<link rel="apple-touch-icon" sizes="76x76" href="img/splash/touch-icon-ipad.png">
<link rel="apple-touch-icon" sizes="120x120" href="img/splash/touch-icon-iphone-retina.png">
<link rel="apple-touch-icon" sizes="152x152" href="img/splash/touch-icon-ipad-retina.png">
<!-- iOS web-app metas : hides Safari UI Components and Changes Status Bar Appearance -->
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="apple-mobile-web-app-status-bar-style" content="black">
<!-- Startup image for web apps -->
<link rel="apple-touch-startup-image" href="img/splash/ipad-landscape.png" media="screen and (min-device-width: 481px) and (max-device-width: 1024px) and (orientation:landscape)">
<link rel="apple-touch-startup-image" href="img/splash/ipad-portrait.png" media="screen and (min-device-width: 481px) and (max-device-width: 1024px) and (orientation:portrait)">
<link rel="apple-touch-startup-image" href="img/splash/iphone.png" media="screen and (max-device-width: 320px)" -->
<script type="text/javascript">
</script>
</head>
<body>
<script type="text/javascript">__meteor_runtime_config__ = JSON.parse(decodeURIComponent("%7B%22meteorRelease%22%3A%22METEOR%402.16%22%2C%22gitCommitHash%22%3A%2205015b245173d3a052a61eb5dccd86cd6b311cd5%22%2C%22meteorEnv%22%3A%7B%22NODE_ENV%22%3A%22production%22%2C%22TEST_METADATA%22%3A%22%7B%7D%22%7D%2C%22PUBLIC_SETTINGS%22%3A%7B%22debugMode%22%3Afalse%2C%22pmaainterface%22%3A%22http%3A%2F%2F10.0.1.27%3A4001%2Frestapi.json%22%2C%22pmaaurl%22%3A%2210.0.1.27%3A4001%22%2C%22pmaaRestEndpoint%22%3A%7B%22url%22%3A%22https%3A%2F%2F10.0.1.27%3A18443%2Frest%2Fv1%22%2C%22username%22%3A%22U2FsdGVkX19DbVffva%2F3DE7Hzw93q36L%2BDQXfNhZrN8%3D%22%2C%22password%22%3A%22U2FsdGVkX1%2FYALRNsm75r5ZaJjYRBqDDk6Je0mvUk38%3D%22%2C%22API_PORT_INFO_ZIP_REPORT_DOWNLOAD_IN_CLUSTER_ENV%22%3A%22%3A18443%2Frest%2Fv1%22%7D%2C%22HTTP_NODE_HOST_URL%22%3A%2210.0.1.27%22%2C%22HTTP_NODE_APP_PORT%22%3A5050%2C%22HTTPS_NODE_APP_PORT%22%3A6060%7D%2C%22ROOT_URL%22%3A%22http%3A%2F%2Flocalhost%22%2C%22ROOT_URL_PATH_PREFIX%22%3A%22%22%2C%22reactFastRefreshEnabled%22%3Atrue%2C%22autoupdate%22%3A%7B%22versions%22%3A%7B%22web.browser%22%3A%7B%22version%22%3A%22bc9f08ebe24a7895b078a85e0d624545d33d8911%22%2C%22versionRefreshable%22%3A%22cb466d522a3fa0dbb07db0501e5d9cd6b1554032%22%2C%22versionNonRefreshable%22%3A%22ddebe56116507d6a404c59a811e60db3dc85af02%22%2C%22versionReplaceable%22%3A%22fde72c711cd965fe023eadaedafa4dbf0d783c3d%22%7D%2C%22web.browser.legacy%22%3A%7B%22version%22%3A%220ae0590d32f185cbd0b04f91ff4927c57857cf0b%22%2C%22versionRefreshable%22%3A%22cb466d522a3fa0dbb07db0501e5d9cd6b1554032%22%2C%22versionNonRefreshable%22%3A%22997fd5bda9ab685976974d126f374d7f26eb5e51%22%2C%22versionReplaceable%22%3A%22fde72c711cd965fe023eadaedafa4dbf0d783c3d%22%7D%7D%2C%22autoupdateVersion%22%3Anull%2C%22autoupdateVersionRefreshable%22%3Anull%2C%22autoupdateVersionCordova%22%3Anull%2C%22appId%22%3A%221f6utbarzx8ti1wz7axz%22%7D%2C%22appId%22%3A%221f6utbarzx8ti1wz7axz%22%2C%22isModern%22%3Afalse%7D"))</script>
<script type="text/javascript" src="/40b167613d9106bbc07984c73c5a30d7208a1855.js?meteor_js_resource=true"></script>
journalctl -f -u caddy
May 22 12:48:42 caddy systemd[1]: Started caddy.service - Caddy.
May 22 12:48:42 caddy caddy[45518]: {"level":"info","ts":1747932522.8310065,"msg":"serving initial configuration"}
May 22 12:48:42 caddy caddy[45518]: {"level":"info","ts":1747932522.8347163,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/var/lib/caddy/.local/share/caddy","instance":"62fff2c8-6423-494c-b985-4276cd80fc82","try_again":1748018922.8347154,"try_again_in":86399.9999998}
May 22 12:48:42 caddy caddy[45518]: {"level":"info","ts":1747932522.8347795,"logger":"tls","msg":"finished cleaning storage units"}
May 22 12:48:50 caddy caddy[45518]: {"level":"debug","ts":1747932530.0338025,"logger":"events","msg":"event","name":"tls_get_certificate","id":"2f978f2d-46fe-45f4-bdc2-4c421e637064","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,157,156,61,60,53,47,255],"ServerName":"smx.lymeaccess.net","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"10.0.1.12","Port":36314,"Zone":""},"LocalAddr":{"IP":"10.0.1.17","Port":3445,"Zone":""}}}}
May 22 12:48:50 caddy caddy[45518]: {"level":"debug","ts":1747932530.0338962,"logger":"tls.handshake","msg":"choosing certificate","identifier":"smx.lymeaccess.net","num_choices":1}
May 22 12:48:50 caddy caddy[45518]: {"level":"debug","ts":1747932530.0339026,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"smx.lymeaccess.net","subjects":["smx.lymeaccess.net"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"ffbaafe7be4afc2c55eede738333c0b69c5b5df25ad68b9f74783de26ba54d6d"}
May 22 12:48:50 caddy caddy[45518]: {"level":"debug","ts":1747932530.0339093,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"10.0.1.12","remote_port":"36314","subjects":["smx.lymeaccess.net"],"managed":true,"expiration":1754591579,"hash":"ffbaafe7be4afc2c55eede738333c0b69c5b5df25ad68b9f74783de26ba54d6d"}
May 22 12:48:50 caddy caddy[45518]: {"level":"debug","ts":1747932530.0526247,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"smx.lymeinternal.net:3443","total_upstreams":1}
May 22 12:48:50 caddy caddy[45518]: {"level":"debug","ts":1747932530.056786,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"smx.lymeinternal.net:3443","duration":0.004127044,"request":{"remote_ip":"10.0.1.12","remote_port":"36314","client_ip":"10.0.1.12","proto":"HTTP/2.0","method":"GET","host":"smx.lymeaccess.net:3445","uri":"/","headers":{"User-Agent":["curl/8.5.0"],"Accept":["*/*"],"X-Forwarded-For":["10.0.1.12"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["smx.lymeaccess.net:3445"],"Via":["2.0 Caddy"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"smx.lymeaccess.net"}},"headers":{"Location":["https://smx.lymeaccess.net:3443/"],"Date":["Thu, 22 May 2025 16:48:50 GMT"]},"status":302}
May 22 13:02:37 caddy caddy[45518]: {"level":"debug","ts":1747933357.3790212,"logger":"events","msg":"event","name":"tls_get_certificate","id":"bf3b2a4f-852b-4603-8aa7-34db471f1c4f","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,157,156,61,60,53,47,255],"ServerName":"smx.lymeaccess.net","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"10.0.1.12","Port":52580,"Zone":""},"LocalAddr":{"IP":"10.0.1.17","Port":3445,"Zone":""}}}}
May 22 13:02:37 caddy caddy[45518]: {"level":"debug","ts":1747933357.3790817,"logger":"tls.handshake","msg":"choosing certificate","identifier":"smx.lymeaccess.net","num_choices":1}
May 22 13:02:37 caddy caddy[45518]: {"level":"debug","ts":1747933357.3790922,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"smx.lymeaccess.net","subjects":["smx.lymeaccess.net"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"ffbaafe7be4afc2c55eede738333c0b69c5b5df25ad68b9f74783de26ba54d6d"}
May 22 13:02:37 caddy caddy[45518]: {"level":"debug","ts":1747933357.3791022,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"10.0.1.12","remote_port":"52580","subjects":["smx.lymeaccess.net"],"managed":true,"expiration":1754591579,"hash":"ffbaafe7be4afc2c55eede738333c0b69c5b5df25ad68b9f74783de26ba54d6d"}
May 22 13:02:37 caddy caddy[45518]: {"level":"debug","ts":1747933357.3977475,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"smx.lymeinternal.net:3443","total_upstreams":1}
May 22 13:02:37 caddy caddy[45518]: {"level":"debug","ts":1747933357.412196,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"smx.lymeinternal.net:3443","duration":0.014408559,"request":{"remote_ip":"10.0.1.12","remote_port":"52580","client_ip":"10.0.1.12","proto":"HTTP/2.0","method":"GET","host":"smx.lymeaccess.net:3445","uri":"/","headers":{"User-Agent":["curl/8.5.0"],"Accept":["*/*"],"X-Forwarded-For":["10.0.1.12"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["smx.lymeaccess.net:3445"],"Via":["2.0 Caddy"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"smx.lymeaccess.net"}},"headers":{"Content-Type":["text/html; charset=utf-8"],"Date":["Thu, 22 May 2025 17:02:37 GMT"],"X-Content-Type-Options":["nosniff"],"P3p":["CP=\"IDC DSP COR ADM DEVi TAIi PSA PSD IVAi IVDi CONi HIS OUR IND CNT\""],"X-Frame-Options":["DENY"],"Content-Security-Policy":["default-src 'self' data: https://blue.calix.com; script-src 'self' 'unsafe-inline' 'unsafe-eval' data: https://blue.calix.com; connect-src * 'self' data: https://blue.calix.com; img-src data: 'self' https://blue.calix.com; style-src 'self' 'unsafe-inline' data: https://blue.calix.com;"],"Vary":["Accept-Encoding"],"Access-Control-Allow-Origin":["*"]},"status":200}
May 22 13:03:52 caddy caddy[45518]: {"level":"debug","ts":1747933432.258722,"logger":"events","msg":"event","name":"tls_get_certificate","id":"a600e97e-c6cd-4ca9-9e67-4ddb3d461c86","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,157,156,61,60,53,47,255],"ServerName":"smx.lymeaccess.net","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"10.0.1.12","Port":49628,"Zone":""},"LocalAddr":{"IP":"10.0.1.17","Port":3445,"Zone":""}}}}
May 22 13:03:52 caddy caddy[45518]: {"level":"debug","ts":1747933432.2587845,"logger":"tls.handshake","msg":"choosing certificate","identifier":"smx.lymeaccess.net","num_choices":1}
May 22 13:03:52 caddy caddy[45518]: {"level":"debug","ts":1747933432.2596972,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"smx.lymeaccess.net","subjects":["smx.lymeaccess.net"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"ffbaafe7be4afc2c55eede738333c0b69c5b5df25ad68b9f74783de26ba54d6d"}
May 22 13:03:52 caddy caddy[45518]: {"level":"debug","ts":1747933432.2597225,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"10.0.1.12","remote_port":"49628","subjects":["smx.lymeaccess.net"],"managed":true,"expiration":1754591579,"hash":"ffbaafe7be4afc2c55eede738333c0b69c5b5df25ad68b9f74783de26ba54d6d"}
May 22 13:03:52 caddy caddy[45518]: {"level":"debug","ts":1747933432.276992,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"smx.lymeinternal.net:3443","total_upstreams":1}
May 22 13:03:52 caddy caddy[45518]: {"level":"debug","ts":1747933432.2833946,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"smx.lymeinternal.net:3443","duration":0.006361476,"request":{"remote_ip":"10.0.1.12","remote_port":"49628","client_ip":"10.0.1.12","proto":"HTTP/2.0","method":"GET","host":"smx.lymeaccess.net:3445","uri":"/","headers":{"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["smx.lymeaccess.net:3445"],"Via":["2.0 Caddy"],"User-Agent":["curl/8.5.0"],"Accept":["*/*"],"X-Forwarded-For":["10.0.1.12"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"smx.lymeaccess.net"}},"headers":{"Content-Security-Policy":["default-src 'self' data: https://blue.calix.com; script-src 'self' 'unsafe-inline' 'unsafe-eval' data: https://blue.calix.com; connect-src * 'self' data: https://blue.calix.com; img-src data: 'self' https://blue.calix.com; style-src 'self' 'unsafe-inline' data: https://blue.calix.com;"],"Content-Type":["text/html; charset=utf-8"],"X-Content-Type-Options":["nosniff"],"Access-Control-Allow-Origin":["*"],"P3p":["CP=\"IDC DSP COR ADM DEVi TAIi PSA PSD IVAi IVDi CONi HIS OUR IND CNT\""],"Vary":["Accept-Encoding"],"Date":["Thu, 22 May 2025 17:03:52 GMT"],"X-Frame-Options":["DENY"]},"status":200}
Output with http access disallowed on the smx.lymeinternal.net server.
* IPv6: (none)
* using HTTP/2
> GET / HTTP/2
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Thu, 22 May 2025 16:45:42 GMT
* Connection #0 to host smx.lymeaccess.net left intact
root@caddy:/# journalctl -f -u caddy
May 22 12:45:39 caddy caddy[45497]: {"level":"info","ts":1747932339.4033139,"msg":"serving initial configuration"}
May 22 12:45:39 caddy caddy[45497]: {"level":"info","ts":1747932339.408745,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/var/lib/caddy/.local/share/caddy","instance":"62fff2c8-6423-494c-b985-4276cd80fc82","try_again":1748018739.4087439,"try_again_in":86399.99999977}
May 22 12:45:39 caddy caddy[45497]: {"level":"info","ts":1747932339.4088173,"logger":"tls","msg":"finished cleaning storage units"}
May 22 12:45:42 caddy caddy[45497]: {"level":"debug","ts":1747932342.046613,"logger":"events","msg":"event","name":"tls_get_certificate","id":"e3c40d53-5888-4066-9871-209fcff8c225","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,157,156,61,60,53,47,255],"ServerName":"smx.lymeaccess.net","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"10.0.1.12","Port":36562,"Zone":""},"LocalAddr":{"IP":"10.0.1.17","Port":3445,"Zone":""}}}}
May 22 12:45:42 caddy caddy[45497]: {"level":"debug","ts":1747932342.0467558,"logger":"tls.handshake","msg":"choosing certificate","identifier":"smx.lymeaccess.net","num_choices":1}
May 22 12:45:42 caddy caddy[45497]: {"level":"debug","ts":1747932342.0467644,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"smx.lymeaccess.net","subjects":["smx.lymeaccess.net"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"ffbaafe7be4afc2c55eede738333c0b69c5b5df25ad68b9f74783de26ba54d6d"}
May 22 12:45:42 caddy caddy[45497]: {"level":"debug","ts":1747932342.0467715,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"10.0.1.12","remote_port":"36562","subjects":["smx.lymeaccess.net"],"managed":true,"expiration":1754591579,"hash":"ffbaafe7be4afc2c55eede738333c0b69c5b5df25ad68b9f74783de26ba54d6d"}
May 22 12:45:42 caddy caddy[45497]: {"level":"debug","ts":1747932342.0652976,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"smx.lymeinternal.net:3443","total_upstreams":1}
May 22 12:45:42 caddy caddy[45497]: {"level":"debug","ts":1747932342.0674367,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"smx.lymeinternal.net:3443","duration":0.002111685,"request":{"remote_ip":"10.0.1.12","remote_port":"36562","client_ip":"10.0.1.12","proto":"HTTP/2.0","method":"GET","host":"smx.lymeaccess.net:3445","uri":"/","headers":{"User-Agent":["curl/8.5.0"],"Accept":["*/*"],"X-Forwarded-For":["10.0.1.12"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["smx.lymeaccess.net:3445"],"Via":["2.0 Caddy"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"smx.lymeaccess.net"}},"error":"tls: failed to verify certificate: x509: certificate signed by unknown authority"}
May 22 12:45:42 caddy caddy[45497]: {"level":"error","ts":1747932342.0674784,"logger":"http.log.error","msg":"tls: failed to verify certificate: x509: certificate signed by unknown authority","request":{"remote_ip":"10.0.1.12","remote_port":"36562","client_ip":"10.0.1.12","proto":"HTTP/2.0","method":"GET","host":"smx.lymeaccess.net:3445","uri":"/","headers":{"Accept":["*/*"],"User-Agent":["curl/8.5.0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"smx.lymeaccess.net"}},"duration":0.002247692,"status":502,"err_id":"awux4x0mu","err_trace":"reverseproxy.statusError (reverseproxy.go:1390)"}
Output with http access disallowed on the smx.lymeinternal.net server and tls_insecure_skip_verify uncommented.
* IPv6: (none)
* using HTTP/2
> GET / HTTP/2
< HTTP/2 302
< date: Thu, 22 May 2025 16:48:50 GMT
< via: 1.1 Caddy
caddy version v2.10.0
xcaddy build
–with GitHub - caddy-dns/cloudflare: Caddy module: dns.providers.cloudflare · GitHub
Debian 12 systemd
sudo systemctl daemon-reload
sudo systemctl enable --now caddy
Type=notify
# auto_https disable_certs
(headers) {
-location
https://smx.lymeaccess.net:3445 {
reverse_proxy https://smx.lymeinternal.net:3443 {
tls
# tls_insecure_skip_verify
tls_server_name smx.lymeaccess.net
import headers
https://smx.lymeaccess.net:18445 {
reverse_proxy https://10.0.1.27:18443 {
tls
Settings changed on smx.lymeaccess.net. As of posting http access is disabled.
Y: You are enabling http access and can access SMx with http on port 3000 and https on port 3443
N: You are disabling http access and can access SMx with https on port 3443
