I run caddy with systemctl:
ExecStart=caddy run --eviron --config
ExecReload=caddy reload --config
caddy reload to reload my config =)
(cloudflare) {
dns cloudflare <token>
(logs) {
level DEBUG
output file <logpath> {
roll_size 100mb
roll_keep 2
roll_keep_for 72h
http://sunnybanlist.axi92.at {
import cloudflare
rewrite * /axi92/sunny-banlist/master/banlist.txt
reverse_proxy https://raw.githubusercontent.com
import logs
I play a game (ark) that can operate a banlist from an weburl but it is only working over http not https. So I try to serve a raw github file over http with caddy.
I like to access http://sunnybanlist.axi92.at and it shows me the content of https://raw.githubusercontent.com/axi92/sunny-banlist/master/banlist.txt but always keeps http because the gameserver only can access http…
"level": "error",
"ts": 1624491808.2654796,
"logger": "http.log.access.log0",
"msg": "handled request",
"request": {
"remote_addr": "172.68.110.12:11370",
"proto": "HTTP/1.1",
"method": "GET",
"host": "sunnybanlist.axi92.at",
"uri": "/",
"headers": {
"Cf-Ray": [
"664194294d091e61-MUC"
"X-Forwarded-Proto": [
"http"
"User-Agent": [
"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:89.0) Gecko/20100101 Firefox/89.0"
"Pragma": [
"no-cache"
"Cache-Control": [
"no-cache"
"Accept-Encoding": [
"gzip"
"X-Forwarded-For": [
"x.x.x.x"
"Cf-Visitor": [
"{\"scheme\":\"http\"}"
"Accept-Language": [
"de,en-US;q=0.7,en;q=0.3"
"Dnt": [
"1"
"Cookie": [
"cf_ob_info=525:664193ef0ac41e65:MUC; cf_use_ob=0"
"Connection": [
"Keep-Alive"
"Cf-Request-Id": [
"0adcdaedcc00001e61233a6000000001"
"Cf-Ipcountry": [
"AT"
"Cf-Connecting-Ip": [
"x.x.x.x"
"Cdn-Loop": [
"cloudflare"
"Accept": [
"text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8"
"1"
"common_log": "172.68.110.12 - - [24/Jun/2021:01:43:28 +0200] \"GET / HTTP/1.1\" 404 5142",
"duration": 0.024755508,
"size": 5142,
"status": 404,
"resp_headers": {
"Accept-Ranges": [
"bytes"
"Date": [
"Wed, 23 Jun 2021 23:43:28 GMT"
"X-Served-By": [
"cache-fra19144-FRA"
"Vary": [
"Accept-Encoding"
"Content-Security-Policy": [
"default-src 'none'; style-src 'unsafe-inline'; img-src data:; connect-src 'self'"
"Content-Length": [
"5142"
"Content-Type": [
"text/html; charset=utf-8"
"X-Github-Request-Id": [
"696A:0342:222D5D:26BA81:60D3C2AB"
"Via": [
"1.1 varnish"
"X-Cache": [
"HIT"
"X-Fastly-Request-Id": [
"dfcd6277c5eaf7cfe579259a3811be3a5eb98982"
"Server": [
"Caddy",
"GitHub.com"
"X-Cache-Hits": [
"1"
"Content-Encoding": [
"gzip"
"Age": [
"1141"
"X-Timer": [
"S1624491808.268492,VS0,VE1"
"Etag": [
"W/\"5f7bc6b3-239b\""
