caddy:latest (2.4.3)
I run the docker image through a docker-compose
Docker on Ubuntu 20.04 Server
None?
version: "3.5"
jellyfin:
image: ghcr.io/linuxserver/jellyfin
container_name: jellyfin
- PUID=1000
- PGID=1000
- TZ=Asia/Kolkata
- /home/junglesucks/config/jellyfin-config:/config
- /media/serverdata/tv:/data/tvshows
- /media/serverdata/movies:/data/movies
image: caddy:2.4.3
- 443:443
- /home/junglesucks/config/caddy-config:/config
- /home/junglesucks/data/caddy-data:/data
http://localhost {
reverse_proxy http://localhost:8096
When I connect to the host ip from the same network (or even if I curl http://localhost in the server) I get a white screen/blank response.
{"level":"info","ts":1628895370.4107208,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"},
{"level":"warn","ts":1628895370.4117415,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2},
{"level":"info","ts":1628895370.4125645,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]},
{"level":"info","ts":1628895370.4127584,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80},
{"level":"info","ts":1628895370.4132984,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002e2f50"},
{"level":"info","ts":1628895370.414028,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"},
{"level":"info","ts":1628895370.4141593,"msg":"serving initial configuration"},
{"level":"info","ts":1628895370.4142165,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"},
{"level":"info","ts":1628895370.4151764,"logger":"tls","msg":"finished cleaning storage units"},
{"level":"error","ts":1628895872.2538195,"logger":"http.log.error","msg":"dial tcp 127.0.0.1:8096: connect: connection refused","request":{"remote_addr":"172.19.0.1:36142","proto":"HTTP/1.1","method":"GET","host":"localhost","uri":"/","headers":{"Accept":["*/*"],"User-Agent":["curl/7.68.0"]}},"duration":0.000320835,"status":502,"err_id":"39egzrgck","err_trace":"reverseproxy.statusError (reverseproxy.go:857)"}
No idea what I can try
NA
