Reverse proxy for Transmission [2]
I would like to use reverse proxy for my transmission server. It’s a bit tricky as I found here:
…I followed this topic, but I am still unable to make it work.
Here is my config:
(gzipconf) {
gzip {
ext *
level 7
min_length 1
(addheader) {
header / {
X-Frame-Options "DENY"
-Server
transmission.int.mydomain.com {
        log /var/log/caddy/transmission.int.mydomain.com.log
        errors /var/log/caddy/errors.log
        import gzipconf
        import addheader
        ipfilter / {
        rule allow
        database /etc/caddy/geolite.mmdb
        country SK HU HR
        import int-auth
        proxy / http://192.168.1.54:9091 {
           keepalive 32
           websocket
I am trying to access on https://transmission.int.mydomain.com:
It was a transmission config error:
In transmission settings.json set rpc-host-whitelist to “*”
After that it should work.
