1. Output of caddy version:
v2.4.3
Raspberry Pi, Bulleye using systemctl with Caddyfile
sudo systemctl caddy start
www.photo.website.com, photo.website.com {
reverse_proxy 192.168.25.210:8025
The above caddyfile works fine … The port 8025 is a normal http port for the synology photos application. The problem occurs if I change the port to the https port for the Synology photos app.
reverse_proxy 192.168.25.210:8935
A Browser displays the message
400 BAD Request
The plain HTTP request was sent to HTTPS port
I’ve tried numerous options with the transport http but no sucess.
It looks like caddy is only using https as far as the caddy server and not providing a certificate to the internal address. Is this the default and if so how do I get caddy to server https between the caddy server and the internal application.
The caddy reverse proxy is inside a dmz but I would like to use https all the way to the endpoint.
Apologies if this is a dumb question but this is an early excursion into this type of deployment, so I am trying to understand things before any live applications are deployed.
