Reverse Proxy for Nextcloud Office
Hey everyone,
I am trying to set up Nextcloud on my home server and I keep getting the same error all the time, no matter what I try. I think this comes from the fact, that I use a Caddy Podman Container as a reverse proxy in front of the Nextcloud Pod.
The error I keep getting is the following:
Your browser has been unable to connect to the Collabora server: http://nextcloud.my.domain
This URL is determined on the Collabora server either from the configured URL or the server_name parameter in coolwsd.xml.
My Nextcloud set up looks the following way:
caddy-reverse-proxy.container
[Container]
ContainerName=caddy-reverse-proxy
Image=docker.io/library/caddy:latest
AutoUpdate=registry
PublishPort=80:80
PublishPort=443:443
Volume=/mnt/storage/reverse-proxy/Caddyfile:/etc/caddy/Caddyfile:z
Volume=/mnt/storage/reverse-proxy/data:/data:z
Network=host
Restart=always
WantedBy=default.target
Caddyfile for the reverse proxy:
    email my.address@proton.me
nextcloud.my.domain {
    reverse_proxy 127.0.0.1:8080 {
        header_up Host {host}
        header_up X-Real-IP {remote_ip}
        header_up X-Forwarded-For {remote_ip}
Nextcloud Pod and Containers:
[Pod]
PodName=nextcloud
PublishPort=8080:80
Restart=always
Caddy Container:
[Container]
ContainerName=caddy-nextcloud
Pod=nextcloud.pod
AutoUpdate=registry
Volume=/mnt/storage/nextcloud/nextcloud:/var/www/html:z
Volume=/mnt/storage/nextcloud/caddy/Caddyfile:/etc/caddy/Caddyfile:z
After=nextcloud.pod
After=mariadb-nextcloud.container
After=nextcloud-app.container
Requires=nextcloud.pod
Requires=mariadb-nextcloud.container
Requires=nextcloud-app.container
Restart=always
Caddyfile for the Nextcloud Caddy Container:
    root * /var/www/html
    php_fastcgi nextcloud-app:9000 {
        root /var/www/html
        env front_controller_active true
        output file /data/nextcloud-access.log
        Strict-Transport-Security "max-age=15768000;includeSubDomains;preload"
    @forbidden {
        path /.htaccess
        path /data/*
        path /config/*
        path /db_structure
        path /.xml
        path /README
        path /3rdparty/*
        path /lib/*
        path /templates/*
        path /occ
        path /console.php
    respond @forbidden 404
Database and Nextcloud Containers:
[Container]
ContainerName=mariadb-nextcloud
Pod=nextcloud.pod
Image=docker.io/library/mariadb:latest
AutoUpdate=registry
Volume=/mnt/storage/nextcloud/mariadb:/var/lib/mysql:z
Environment=MYSQL_DATABASE=nextcloud
Environment=MYSQL_USER=nextcloud
Environment=MYSQL_PASSWORD=PASSWORD
Environment=MYSQL_ROOT_PASSWORD=PASSWORD
Exec=--transaction-isolation=READ-COMMITTED --log-bin=binlog --binlog-format=ROW --max_allowed_packet=256000000
After=nextcloud.pod
Restart=always
[Container]
ContainerName=nextcloud-app
Pod=nextcloud.pod
Image=docker.io/library/nextcloud:fpm
AutoUpdate=registry
Environment=MYSQL_HOST=127.0.0.1
Volume=/mnt/storage/nextcloud/data:/var/www/html/data:z
After=nextcloud.pod
Restart=always
I have also added the following lines to the config.php in the Nextcloud config folder:
  'forwarded_for_headers' => ['HTTP_X_FORWARDED_FOR'],
  'trusted_proxies'   => ['127.0.0.1'], // The IP of your reverse proxy
  'overwrite.cli.url' => 'https://nextcloud.ppflaum.ch',
  'overwritehost'     => 'nextcloud.ppflaum.ch',
  'overwriteprotocol' => 'https',
This was apparently needed for my applications to trust Nextcloud as the Nextcloud container only sees as http connection and does not know that the connection is actually over https and therefore secure.
I would be very thankful to anybody who shares their ideas or experiences with me, as I really don’t know what to try anymore.
