Hi I cannot access Jellyfin externally after setting up the Caddy reverse proxy. The domain is setup in Cloudflare and I have used the below example config: redacted.com {
reverse_proxy 127.0.0.1:8096
dns cloudflare apikey
In Cloudflare the domain points to my public IP address and I have setup port forwards to my server and opened ports 80,443 and 2019
No error messages I can find, when trying to connect externally it just loads and then times out. I am unsure if I am missing any part of the setup or firewall rules.
Don’t open port 2019. That’s Caddy’s admin port, and should never be exposed publicly, otherwise anyone could change your Caddy config and do evil things.
I don’t understand what that means. Show the behaviour with curl -v. Enable the debug global option and show what you see in your logs from making a request.
Thanks for your reply, i’ve closed the port 2019 now, I was not aware that this was the admin port and some tutorials I watched recommended I open this.
I’ve enabled debugging by adding the debug line and figured it out now. As a test I disabled all Firewalls on my server temporarily and got it working so it must be some firewall port being blocked and I should be able to figure it out now.
Quick aside: I think that even if the port was opened publicly on the firewall/router, it still wouldn’t be accessible remotely, as Caddy specifically binds to localhost:2019, so the packets would have to somehow come from the loopback interface. And that routing would be done by the kernel / network stack, not even Caddy.
I dunno, maybe there’s a way to fake out the networking stack, but if so I haven’t seen it.
True, but I just wanted to correct the misconception that opening port 2019 is “a good thing”, which it’s definitely not, even if Caddy won’t accept requests by default.
