1. Output of caddy version
Windows 10 x64
caddy reverse-proxy --from encom58.ddns.net --to 127.0.0.1:8096
N/A
No config, been using the one-line command for the last 8 months
Router rebooted, no longer able to connect to Jellyfin server through the reverse-proxy.
2022/08/02 07:25:30.613 ←[33mWARN←[0m admin admin endpoint disabled
2022/08/02 07:25:30.614 ←[34mINFO←[0m http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "proxy", "https_port": 443}
2022/08/02 07:25:30.614 ←[34mINFO←[0m http enabling automatic HTTP->HTTPS redirects {"server_name": "proxy"}
2022/08/02 07:25:30.614 ←[34mINFO←[0m tls.cache.maintenance started background certificate maintenance {"cache": "0xc00008abd0"}
2022/08/02 07:25:30.615 ←[34mINFO←[0m tls cleaning storage unit {"description": "FileStorage:C:\\Users\\Jake\\AppData\\Roaming\\Caddy"}
2022/08/02 07:25:30.617 ←[34mINFO←[0m http enabling automatic TLS certificate management {"domains": ["encom58.ddns.net"]}
2022/08/02 07:25:30.623 ←[34mINFO←[0m tls finished cleaning storage units
2022/08/02 07:25:30.630 ←[34mINFO←[0m autosaved config (load with --resume flag) {"file": "C:\\Users\\Jake\\AppData\\Roaming\\Caddy\\autosave.json"}
Caddy proxying https://encom58.ddns.net -> 127.0.0.1:8096
I checked to see if the router reboot removed the port forwarding settings for ports 80 and 443, but both ports are still being forwarded. I then checked to see if the local IP for the server changed, but my router’s control panel shows that the server is at the same local IP, and further I’m able to connect to the Jellyfin server on LAN by using that local IP. I checked if my DDNS was pointing at my correct external IP, and it is; I also checked that my ISP was not blocking ports 80 or 443, and I confirmed they are open on my external IP. As such, I have confirmed the problem is not with Jellyfin, my DDNS, or my router settings. I have followed all steps listed here without being able to solve the problem.
