Reverse Proxy for Front and Backend Inconsistency
I am hosting my react frontend with vite (port 5173) and my nodejs backend with express (port 5000). I am trying to use Caddy to reverse proxy a request to the proper server based on the request url. when i test this by making a request with
curl -X GET "heimerdinger.ecs-iot.com/api/"
it is horribly inconsistent. Yes, about half the time the request is forwarded to my backend API server. However, the other half of the time it returns HTML from my frontend vite server. In the below code blog for step 2 you can see one request where it returned the html and another where it got the response from my API endpoint.
(default) ➜  ~ curl -X GET "https://heimerdinger.ecs-iot.com/api/"
<!doctype html>
<html lang="en">
  <head>
    <script type="module">
import RefreshRuntime from "/@react-refresh"
RefreshRuntime.injectIntoGlobalHook(window)
window.$RefreshReg$ = () => {}
window.$RefreshSig$ = () => (type) => type
window.__vite_plugin_react_preamble_installed__ = true
</script>
    <script type="module" src="/@vite/client"></script>
    <meta charset="UTF-8" />
    <meta name="viewport" content="width=device-width, initial-scale=1.0" />
    <title>Proxy Box</title>
    <script src="https://unpkg.com/@tailwindcss/browser@4"></script>
  </head>
  <body>
    <div id="app"></div>
    <script type="module" src="/src/main.tsx?t=1739473852618"></script>
  </body>
</html>
API ENDPOINT!%
v2.9.1
I followed the Ubuntu installation instructions from the caddy website.
Running an ubuntu 24.04 vm via Parallels.
caddy adapt
sudo caddy run
heimerdinger.ecs-iot.com {
	handle /api* {
		reverse_proxy :5000
		basic_auth / {
			admin <password>
		reverse_proxy :5173
		dns cloudflare <cloudflare-token>
I should add - I spaced this when I posted yesterday, but I used xcaddy to install the cloudflare dns custom build from this repo GitHub - caddy-dns/cloudflare: Caddy module: dns.providers.cloudflare.
I have solved the issue. I unknowingly had multiple instances of Caddy running. When i killed all the old instances and restarted caddy it worked no issues.
