Tried both 2 and 2.2.1
I run Caddy as a reverse proxy to external cloudfront domains.
Using Ubunte 18.0.4 on AWS Lightsail with docker-compose.
docker-compose up
docker-compose.yml
version: "3.7"
web:
external: true
image: caddy:2.2.1-alpine
- "$HOME/Caddyfile:/etc/Caddyfile"
- "$HOME/caddy:/root/.caddy"
- web
grailbyte.de:443 {
reverse_proxy * dcsu781bfzy0r.cloudfront.net:443 {
# added those as they were mentioned in caddy v1 configs / transparent option, default in v2?
header_up X-Real-IP {http.request.remote}
header_up X-Forwarded-For {http.request.remote}
header_up X-Forwarded-Proto {http.request.scheme}
# unfortunately does not work, as rewrite only works for internal urls, according to one post
# rewrite * https://dcsu781bfzy0r.cloudfront.net:443
Getting a 400 error from cloudfront when opening the website → If I redirect, it works like a charm, but I need the client-side url to stay the same. So figured use a reverse-proxy.
No errors logged by Caddy.
tried to solve it
- using rewrite (only for internal, already mentioned above)
- checked if redir works → it does
- added headers as they were in the tutorials for caddy v1 or configuration with option “transparent”. If I recall correctly, that is default behavior for caddy v2, but just to keep it safe.
- Went through all post regarding and/or mentioning cloudfront, as I suspect it to be the problem. Tried all of the suggestions mentioned in those posts. If needed, I will link all of them in a separate answer down below, as I saw new users can only add 4 links.
Used the following ressources apart from the docs as well as community posts
Happy for all the help I can get on this! Really appreciate it!
