$ caddy version
Operating System: Ubuntu 20.04.2 LTS
Kernel: Linux 5.4.0-62-generic
Architecture: x86-64
Running a server on localhost:8081
using Python 3.8.5
Running caddy without a Caddyfile.
$ sudo caddy reverse-proxy --from cs236.cs.byu.edu --to localhost:8081
None
Auto-generated file /root/.config/caddy/autosave.json
"admin":{
"disabled":true
"apps":{
"http":{
"servers":{
"proxy":{
"listen":[
":443"
"routes":[
"handle":[
"handler":"reverse_proxy",
"transport":{
"protocol":"http"
"upstreams":[
"dial":"localhost:8081"
"match":[
"host":[
"cs236.cs.byu.edu"
I’m trying to set up an HTTPS server by running the server normally (HTTP) on port 8081
and running caddy reverse-proxy
(full command given above).
I can do curl localhost:8081
and get the correct response.
I can do curl https://cs236.cs.byu.edu
from the local machine and get the correct response.
If I do curl https://cs236.cs.byu.edu
from any other machine then I get a “Connection refused” error.
This is what it looks like when I start caddy
2021/04/02 08:18:03.657 WARN admin admin endpoint disabled
2021/04/02 08:18:03.658 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "proxy", "https_port": 443}
2021/04/02 08:18:03.659 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "proxy"}
2021/04/02 08:18:03.660 INFO http enabling automatic TLS certificate management {"domains": ["cs236.cs.byu.edu"]}
2021/04/02 08:18:03.658 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc00022c7e0"}
2021/04/02 08:18:03.662 INFO tls cleaned up storage units
2021/04/02 08:18:03.680 INFO autosaved config {"file": "/root/.config/caddy/autosave.json"}
Caddy proxying https://cs236.cs.byu.edu -> http://localhost:8081
If I then do curl https://cs236.cs.byu.edu/
from that same machine, I get the correct response.
from a different machine, I get this error:
$ curl https://cs236.cs.byu.edu
curl: (7) Failed to connect to cs236.cs.byu.edu port 443: Connection refused
I’ve tried:
- Stopping the caddy process and re-starting it without deleting
- Stopping the caddy process and re-starting it, including deleting
- Trying both
curl
and a browser (Google Chrome) to connect from the other machine. - Connecting from the remote machine using various URLs that use different combinations of
http
/https
and specifying the port vs not.
With this, I’ve noticed that going tohttp://cs236.cs.byu.edu
does indeed redirect tohttps://cs236.cs.byu.edu
, but then it gives the sameConnection refused
error.
