Reverse proxy... first installation, almost working
Hi.
Sorry to ask this.
I try this command:
caddy reverse-proxy --from trilium.xxxxxxx.xyz --to 192.168.0.10:8080
And is working perfect i could go to there, is https! all perfect but…
how i make this permanent?
if i just Ctrl+c the caddy stop and nothing is saved.
So, how i need to write the config file to reference that info?
Thanks
I have no idea what platform you’re on, but install Caddy from your package manager: Install — Caddy Documentation
Most of those, like apt or yum install methods will set up a system service for you. Then just modify the config:
trilium.xxxxxxx.xyz
reverse_proxy 192.168.0.10:8080
That’s it.
oh, sorry.
Yes, im in Proxmox, inside a lxc with Alpine.
caddy:~# cat /etc/caddy/Caddyfile
Caddy’s configuration file
see: The Caddyfile — Caddy Documentation
caddy:~#
What i dont know is how write the file to save the config info.
I mean like in Nginx.conf that i made
{server name trilium.xxxxxxxxx.xyz
etc…
192.168.0.10:8000
etc…
Thanks
i suppose that i have to put that kind of info in caddyfile but i dont know how is the format, syntaxis
Start here to learn how the Caddyfile works:
What Matt gave you above is literally a valid Caddyfile.
yep, sorry!
i was just thinking that maybe that was a content, i just came here to copy/paste and try… and found your message! lol
but… it is so weird that with just that all is working¡?¡?¡? but it is.
Thanks!
