1. Output of caddy version
Docker Compose
Ubuntu 22.04
docker compose up -d
caddy docker-compose.yml
version: "3.9"
image: caddy:latest
cap_add:
- NET_ADMIN
- CAP_NET_BIND_SERVICE
- CAP_NET_RAW
- caddy
- "443:443/udp"
- $HOME/Docker/caddy/Caddyfile:/etc/caddy/Caddyfile
- $HOME/Docker/caddy/www:/srv
- $HOME/Docker/caddy/log/:/var/log/
- caddy_data:/data
- caddy_config:/config
caddy_data:
external: true
caddy_config:
external: true
adguard docker-compose.yml:
version: "3.9"
adguard:
image: adguard/adguardhome:latest
container_name: adguard
cap_add:
- NET_ADMIN
- CAP_NET_RAW
- caddy
- "53:53"
- "53:53/udp"
- "853:853"
- "853:853/udp"
- "1443:443"
- "1443:443/udp"
- "3000:3000"
- adguard_data:/opt/adguardhome/work
- adguard_config:/opt/adguardhome/conf
- /var/lib/docker/volumes/caddy_data/_data/caddy/certificates/acme-v02.api.letsencrypt.org-directory/:/etc/ssl/certs/:ro
adguard_data:
external: true
adguard_config:
external: true
external: true
adguard config.yml:
bind_host: 0.0.0.0
bind_port: 3000
beta_bind_port: 0
users:
- name: admin
password: mypass
auth_attempts: 5
block_auth_min: 15
http_proxy: ""
language: ""
debug_pprof: false
web_session_ttl: 720
dns:
bind_hosts:
- 0.0.0.0
port: 53
statistics_interval: 10
querylog_enabled: true
querylog_file_enabled: true
querylog_interval: 2160h
querylog_size_memory: 1000
anonymize_client_ip: false
protection_enabled: true
blocking_mode: default
blocking_ipv4: ""
blocking_ipv6: ""
blocked_response_ttl: 10
parental_block_host: family-block.dns.adguard.com
safebrowsing_block_host: standard-block.dns.adguard.com
ratelimit: 20
ratelimit_whitelist: []
refuse_any: true
upstream_dns:
- quic://family.adguard-dns.com
- tls://family.adguard-dns.com
- tls://family.cloudflare-dns.com
- https://family.cloudflare-dns.com/dns-query
upstream_dns_file: ""
bootstrap_dns:
- 9.9.9.10
- 149.112.112.10
- 2620:fe::10
- 2620:fe::fe:10
all_servers: false
fastest_addr: false
fastest_timeout: 1s
allowed_clients: []
disallowed_clients: []
blocked_hosts:
- version.bind
- id.server
- hostname.bind
trusted_proxies:
- 127.0.0.0/8
- ::1/128
cache_size: 0
cache_ttl_min: 0
cache_ttl_max: 0
cache_optimistic: false
bogus_nxdomain: []
aaaa_disabled: false
enable_dnssec: true
edns_client_subnet: false
max_goroutines: 300
handle_ddr: true
ipset: []
ipset_file: ""
filtering_enabled: true
filters_update_interval: 24
parental_enabled: true
safesearch_enabled: false
safebrowsing_enabled: true
safebrowsing_cache_size: 1048576
safesearch_cache_size: 1048576
parental_cache_size: 1048576
cache_time: 30
rewrites: []
blocked_services: []
upstream_timeout: 10s
private_networks: []
use_private_ptr_resolvers: true
local_ptr_upstreams: []
serve_http3: true
use_http3_upstreams: true
tls:
enabled: true
server_name: "example.com"
force_https: false
port_https: 443
port_dns_over_tls: 853
port_dns_over_quic: 853
port_dnscrypt: 0
dnscrypt_config_file: ""
allow_unencrypted_doh: false
strict_sni_check: false
certificate_chain: ""
private_key: ""
certificate_path: "/etc/ssl/certs/example.com/example.com.crt"
private_key_path: "/etc/ssl/certs/example.com/example.com.key"
filters:
- enabled: true
url: https://adguardteam.github.io/AdGuardSDNSFilter/Filters/filter.txt
name: AdGuard DNS filter
- enabled: true
url: https://adaway.org/hosts.txt
name: AdAway Default Blocklist
whitelist_filters: []
user_rules: []
dhcp:
enabled: false
interface_name: ""
local_domain_name: lan
dhcpv4:
gateway_ip: ""
subnet_mask: ""
range_start: ""
range_end: ""
lease_duration: 86400
icmp_timeout_msec: 1000
options: []
dhcpv6:
range_start: ""
ra_slaac_only: false
ra_allow_slaac: false
clients:
runtime_sources:
whois: true
arp: true
rdns: true
dhcp: true
hosts: true
persistent: []
log_file: ""
log_max_backups: 0
log_max_size: 10
log_max_age: 3
log_compress: false
log_localtime: false
verbose: false
os:
group: ""
user: ""
rlimit_nofile: 0
schema_version: 14
level DEBUG
output file /var/log/caddy.log {
roll_size 10MiB
roll_keep_for 3d
# TLS global settings
email myemail@example.com
example.com {
issuer acme
issuer zerossl
reverse_proxy /dns-query* adguard:1443
I’m trying to run AdGuard Home Docker container behind Caddy to serve DoH and DoT requests, it works perfectly without Caddy and when it’s set to port 443 but when I try to reverse proxy using Caddy to a custom port (1443 since Caddy is listening to 443 obviously!) I get 400 HTTP error code in my DNS client!
Here’s the Caddy log when a request is made:
{"level":"debug","ts":1667697363.2261975,"logger":"tls.handshake","msg":"choosing certificate","identifier":"example.com","num_choices":1}
{"level":"debug","ts":1667697363.2262568,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"example.com","subjects":["example.com"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"2140613c047495444e3f1053b4c0da8f2188ac16d8ce1ab4a1a21b9a8bac3768"}
{"level":"debug","ts":1667697363.2262878,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"x.x.x.x","remote_port":"60232","subjects":["example.com"],"managed":true,"expiration":1675460687,"hash":"2140613c047495444e3f1053b4c0da8f2188ac16d8ce1ab4a1a21b9a8bac3768"}
{"level":"debug","ts":1667697363.3468044,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"adguard:1443","total_upstreams":1}
{"level":"debug","ts":1667697363.3499403,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"adguard:1443","duration":0.003019613,"request":{"remote_ip":"x.x.x.x","remote_port":"60232","proto":"HTTP/2.0","method":"GET","host":"example.com:443","uri":"/dns-query?dns=AAABIAABAAAAAAABCmNsb3VkZmxhcmUDY29tAAABAAEAACkE0AAAAAAADAAKAAi1YqhuIeuOJQ","headers":{"X-Forwarded-Host":["example.com:443"],"Accept":["application/dns-message"],"User-Agent":[""],"X-Forwarded-For":["x.x.x.x"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"h2","server_name":"example.com"}},"headers":{},"status":400}
Here’s the client log:
$ dig +short @127.0.0.1 cloudflare.com A
2022/11/06 04:46:03 279054#17 [debug] github.com/AdguardTeam/dnsproxy/upstream.lookup(): successfully finished lookup for example.com in 485.923451ms using 8.8.8.8:53. Result : [{x.x.x.x }]
2022/11/06 04:46:03 279054#17 [debug] using HTTP/2 for this upstream: HTTP3 support is not enabled
2022/11/06 04:46:03 279054#17 [debug] https://example.com:443/dns-query: sending request A cloudflare.com.
2022/11/06 04:46:03 279054#21 [debug] github.com/AdguardTeam/dnsproxy/upstream.(*bootstrapper).createDialContext.func1(): Dialing to x.x.x.x:443
2022/11/06 04:46:03 279054#21 [debug] github.com/AdguardTeam/dnsproxy/upstream.(*bootstrapper).createDialContext.func1(): dialer has successfully initialized connection to x.x.x.x:443 in 95.20894ms
2022/11/06 04:46:03 279054#17 [debug] https://example.com:443/dns-query: response: expected status 200, got 400 from https://example.com:443/dns-query
2022/11/06 04:46:03 279054#17 [debug] re-creating the http client due to expected status 200, got 400 from https://example.com:443/dns-query
2022/11/06 04:46:03 279054#17 [debug] github.com/AdguardTeam/dnsproxy/proxy.exchangeWithUpstream(): upstream https://example.com:443/dns-query failed to exchange ;cloudflare.com. IN A in 805.853048ms. Cause: expected status 200, got 400 from https://example.com:443/dns-query
2022/11/06 04:46:03 279054#17 [debug] github.com/AdguardTeam/dnsproxy/proxy.(*Proxy).replyFromUpstream(): RTT: 806.07772ms
2022/11/06 04:46:03 279054#17 [debug] github.com/AdguardTeam/dnsproxy/proxy.(*Proxy).logDNSMessage(): OUT: ;; opcode: QUERY, status: SERVFAIL, id: 60012
I have tried substituting reverse_proxy /dns-query* adguard:1443
to reverse_proxy /dns-query* https://example.com:1443
in my Caddyfile but it gives me i/o timeout.
This is all for DoH and I have no idea what to do for DoT! Is Caddy even able to listen to port :853 and proxy it?
NGINX example here
