edit: i’ve since hard coded in the resolver which seems to have fixed that error; however now i get the below error; the ip appears to be load balancers sitting in front of caddy; Any thoughts?
{"level":"info","ts":1670259690.3408582,"logger":"tls.obtain","msg":"releasing lock","identifier":"10.64.7.25"}
{"level":"info","ts":1670259860.3330655,"logger":"tls.on_demand","msg":"obtaining new certificate","remote_ip":"10.142.0.197","remote_port":"45951","server_name":"10.64.7.25"}
{"level":"info","ts":1670259860.3358788,"logger":"tls.obtain","msg":"acquiring lock","identifier":"10.64.7.25"}
{"level":"info","ts":1670259860.3361945,"logger":"tls.obtain","msg":"lock acquired","identifier":"10.64.7.25"}
{"level":"info","ts":1670259860.3368263,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"10.64.7.25"}
{"level":"error","ts":1670259860.3379474,"logger":"tls.obtain","msg":"will retry","error":"[10.64.7.25] Obtain: subject does not qualify for a public certificate: 10.64.7.25","attempt":1,"retrying_in":60,"elapsed":0.001737673,"max_duration":2592000}
1. Output of caddy version
2.6.2
via docker using caddy build
Docker
ROM caddy:2.6.2-builder AS builder
RUN xcaddy build \
--with github.com/gamalan/caddy-tlsredis
FROM caddy:2.6.2
COPY Caddyfile /etc/caddy/
RUN caddy start
on_demand_tls {
interval 1m
burst 5
storage redis {
host "{$REDIS_HOST}"
port {$REDIS_PORT}
address "" // no default, but is build from host+":"+port, if set, then host and port is ignored
username ""
password "{$REDIS_PASSWORD}"
db {$REDIS_DB}
key_prefix "caddytls"
value_prefix "caddy-storage-redis"
timeout 5
tls_enabled "false"
tls_insecure "true"
http:// {
respond /health 200
https:// {
reverse_proxy {$PROXY_UPSTREAM} {
resolvers {$PROXY_RESOLVER}
I’m getting the below error only when having my reverse proxy upstream somewhere the system can’t resolve; and using the transport http resolvers options. If the reverse proxy upstream is set somewhere else and I remove that resolvers line it works. Unfortunately in the production enviro the resolver is required. The resolver is listening on standard port 53 and i’m having trouble understanding from the log error whether it’s having problems with resolving; or connecting after it’s resolved. I’m assuming it’s resolving since it works fine without the resolver step but :shrug: So i’m assuming it’s an error in my configuration. Any insight would be greatly appreciated.
I’ve tried changing resolvers {$PROXY_RESOLVER} to resolvers {$PROXY_RESOLVER}:53 as well with no change.
$PROXY_RESOLVER is an address in the form of something.something.local and the upstream is an http address
{"level":"error","ts":1670209405.8280604,"logger":"http.log.error","msg":"dial tcp: lookup php-.1130453904.svc.cluster.local on 10.62.240.10:53: dial tcp 10.62.240.10:0: connect: connection refused","request":{"remote_ip":"10.142.0.111","remote_port":"36603","proto":"HTTP/2.0","method":"POST","host":"php1130453904.staging231121.com","uri":"/query","headers":{"User-Agent":["curl/7.58.0"],"Accept":["*/*"],"Content-Type":["application/json"],"Content-Length":["178"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"php.1130453904.staging231121.com"}},"duration":0.040958068,"status":502,"err_id":"89zp9xfg1","err_trace":"reverseproxy.statusError (reverseproxy.go:1272)"}
