Reverse Proxy connections from every client?
I want to setup a simple reverse proxy for within my own network (No domain, no connection from the outside) to get a https connection to the tool “spoolman”, installed in VM.
When checking from localhost, it seams to work, but it didn’t accept connections from other clients.
Tried to run the test with
caddy reverse-proxy --to :7912
and with Caddyfile
localhost
reverse_proxy :7912
From localhost it starts with
oliver@spoolman:~$ curl -v https://localhost
*   Trying ::1:443...
* Connected to localhost (::1) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*  CApath: /etc/ssl/certs
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8
From other clients it looks like this
oliver@iobrokervm:~$ curl -v https://192.168.1.31
*   Trying 192.168.1.31:443...
* Connected to 192.168.1.31 (192.168.1.31) port 443 (#0)
* ALPN: offers h2,http/1.1
* OpenSSL/3.0.11: error:0A000438:SSL routines::tlsv1 alert internal error
* Closing connection 0
curl: (35) OpenSSL/3.0.11: error:0A000438:SSL routines::tlsv1 alert internal error
apt install caddy
or
debian 11 (within Proxmox Container)
or
localhost
reverse_proxy :7912
To manage TLS certs, Caddy either needs the names configured ahead of time (so it can issue certs at startup).
Or you can enable On-Demand TLS to have Caddy issue certs as requests come in, but you need to opt-in for that:
https:// {
	tls internal {
		on_demand
	reverse_proxy localhost:7912
Thanks a lot! It’s working now :slight_smile:
