$ caddy version
v2.5.1 h1:bAWwslD1jNeCzDa+jDCNwb8M3UJ2tPa8UZFFzPVmGKs=
I am using Caddy as a reverse proxy to an upstream web server. The upstream web server is running PHP-FPM and I have configured Caddy to check the /ping
endpoint (which, for reasons, I have exposed on port :81 on the upstream server).
This works as expected; based on the config below Caddy checks the upstream’s /ping
every 10 seconds and reacts as expected when the /ping
endpoint doesn’t respond healthy.
The functionality I would like to add is a backup/failover page that would respond in the event that all upstream servers are in an unhealthy state.
I am currently testing this with one upstream and then a “sorry the site is down” page that is served locally from the Caddy VM.
With my current config, Caddy correctly tries to check for the :81/ping
endpoint on both the upstream and itself; however since I don’t have anything listening on :81 on the local Caddy VM, this fails the health checks.
Is there a way to perform normal reverse proxy health checks & load balancing and provide a ‘last resort’ upstream that would respond if no other upstreams are in a healthy state?
Debian 11.3
# caddy run --watch
2022/07/07 21:15:20.243 INFO using adjacent Caddyfile
n/a (but I just use the one from the Caddy Debian repo)
:8080 {
respond "The site you are attempting to connect to is currently unavailable" 504
cloud-test.internal.1904.tech:80 {
reverse_proxy {
to http://nc-node02.colo.1904.tech:80 http://localhost:8080
lb_policy first
header_down "X-Served-By" "Edge05"
flush_interval -1
health_uri /ping
health_port 81
health_interval 60s
health_timeout 10s
health_status 200
I would like my local ‘upstream-of-last-resort’ to be used when all other upstreams are unhealthy and not be subject to the health checks of the other upstreams.
2022/07/08 00:28:55.865 INFO http.handlers.reverse_proxy.health_checker.active HTTP request failed {"host": "localhost:81", "error": "Get \"http://localhost:81/ping\": dial tcp [::1]:81: connect: connection refused"}
I know I can fake it by just having Caddy listen and respond 200 on :81/ping
, but that just seems like a janky workaround that won’t scale well.
