Reverse_proxy and replace_response
2.3.0 h1:fnrqJLa3G5vfxcxmOH/+kJOcunPLhSBnjgIvjXV/QTA=
Built with xcaddy build --with github.com/caddyserver/replace-response
Locally. I just run the built binary on my dev machine.
macOS Big Sur
./caddy run -config ./Caddyfile
None.
(to_staging) {
    reverse_proxy {
        to https://a-private-staging-server.com
        header_up Referer "localhost:9443" "a-private-staging-server.com"
        header_up Host "localhost:9443" "a-private-staging-server.com"
    replace {
        stream
        "a-private-staging-server.com" "localhost:9443"
https://localhost:9443 {
    tls ./proxy-cert.pem ./proxy-pkey.pem
        output stdout
    route /api/* {
        import to_staging
    route {
        reverse_proxy http://localhost:5000
After reverse proxying a request, I want to modify some text in the upstream response body before sending the result to the client. The logs show that the replace_response handler isn’t being invoked at all.
I have tried different plugins. I have tried replacing something very simple like “html” to check that I am not making a typo in the config. I have checked the parsed config through curl -L "http://localhost:2019/config" | jq and can confirm that the handler is correctly registered.
You can change these to use this placeholder. A bit simpler:
The problem you’re seeing is due to directive ordering. The fix is to move replace above reverse_proxy in your snippet.
The way Caddy works is via a middleware-type system. Each handler is chained together by calling the next one in the chain, until one returns without calling the next in the chain, or the last handler is reached. This is how reverse_proxy works, because it’s a “terminal” handler, i.e. it’s a handler that acts as the end of the chain. The replace handler, like encode and a few others like header (if you use the defer option) run on the way back up the chain of handlers, i.e. after having called the next handler in the chain. So if you use route to set the order and have replace after reverse_proxy, then it never gets called because reverse_proxy doesn’t call it.
This is why the docs for replace recommend setting the order for replace like this:
	order replace after encode
i.e. set its order to be after encode’s, which is another handler with the property of running on the way back up the chain. If you use the order global option, then you won’t need to wrap it in a route.
Thank you for the tip!
I tried what you suggested, it did not work.
I have tried:
(to_staging) {
    replace {
        stream
    reverse_proxy {
        header_up Referer {http.reverse_proxy.upstream.hostport}
        output stdout
    route /api/* {
        import to_staging
    route {
and
        output stdout
    handle /api/* {
        replace {
            stream
        reverse_proxy {
    route {
I even tried adding replace before and after reverse_proxy, but did not get any replacement happening.
