caddy version
Running caddy as a downloaded binary. What I’m trying to do is use Caddy as a reverse proxy in front of the Docker socket. Assuming I can get the basics working, I’m planning to add white-listing on specific paths to expose a safe subset of Docker’s functionality (e.g. for monitoring)
OS: Ubuntu 20.04.2 LTS
Docker: 20.10.7
In one terminal
In a second terminal
docker --debug -H tcp://localhost:2379 stats
http://:2379 {
reverse_proxy unix///var/run/docker.sock {
flush_interval -1
Some commands when run from the docker CLI will hang when run via Caddy as a reverse proxy. The stats command which is the example here and also the events command. Others like the info command work just fine, so the basic idea of reverse proxying the socket seems ok.
2021/08/15 13:44:27.244 INFO using adjacent Caddyfile
2021/08/15 13:44:27.245 WARN input is not formatted with 'caddy fmt' {"adapter": "caddyfile", "file": "Caddyfile", "line": 1}
2021/08/15 13:44:27.245 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
2021/08/15 13:44:27.246 DEBUG http starting server loop {"address": "[::]:2379", "http3": false, "tls": false}
2021/08/15 13:44:27.246 INFO autosaved config (load with --resume flag) {"file": "/home/rorym/.config/caddy/autosave.json"}
2021/08/15 13:44:27.247 INFO serving initial configuration
2021/08/15 13:44:27.247 INFO tls cleaning storage unit {"description": "FileStorage:/home/rorym/.local/share/caddy"}
2021/08/15 13:44:27.248 INFO tls finished cleaning storage units
2021/08/15 13:44:27.248 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc0003167e0"}
2021/08/15 13:44:41.184 DEBUG http.handlers.reverse_proxy upstream roundtrip {"upstream": "unix///var/run/docker.sock", "request": {"remote_addr": "127.0.0.1:54704", "proto": "HTTP/1.1", "method": "HEAD", "host": "localhost:2379", "uri": "/_ping", "headers": {"User-Agent": ["Docker-Client/20.10.7 (linux)"], "X-Forwarded-Proto": ["http"], "X-Forwarded-For": ["127.0.0.1"]}}, "headers": {"Ostype": ["linux"], "Pragma": ["no-cache"], "Content-Type": ["text/plain; charset=utf-8"], "Docker-Experimental": ["false"], "Content-Length": ["0"], "Server": ["Docker/20.10.7 (linux)"], "Date": ["Sun, 15 Aug 2021 13:44:41 GMT"], "Api-Version": ["1.41"], "Cache-Control": ["no-cache, no-store, must-revalidate"]}, "status": 200}
2021/08/15 13:44:41.190 DEBUG http.handlers.reverse_proxy upstream roundtrip {"upstream": "unix///var/run/docker.sock", "request": {"remote_addr": "127.0.0.1:54704", "proto": "HTTP/1.1", "method": "GET", "host": "localhost:2379", "uri": "/v1.41/version", "headers": {"X-Forwarded-For": ["127.0.0.1"], "User-Agent": ["Docker-Client/20.10.7 (linux)"], "X-Forwarded-Proto": ["http"]}}, "headers": {"Server": ["Docker/20.10.7 (linux)"], "Date": ["Sun, 15 Aug 2021 13:44:41 GMT"], "Content-Length": ["851"], "Api-Version": ["1.41"], "Content-Type": ["application/json"], "Docker-Experimental": ["false"], "Ostype": ["linux"]}, "status": 200}
2021/08/15 13:44:41.191 DEBUG http.handlers.reverse_proxy upstream roundtrip {"upstream": "unix///var/run/docker.sock", "request": {"remote_addr": "127.0.0.1:54704", "proto": "HTTP/1.1", "method": "GET", "host": "localhost:2379", "uri": "/v1.41/events?filters=%7B%22type%22%3A%7B%22container%22%3Atrue%7D%7D", "headers": {"X-Forwarded-For": ["127.0.0.1"], "User-Agent": ["Docker-Client/20.10.7 (linux)"], "X-Forwarded-Proto": ["http"]}}, "headers": {"Content-Type": ["application/json"], "Docker-Experimental": ["false"], "Ostype": ["linux"], "Server": ["Docker/20.10.7 (linux)"], "Date": ["Sun, 15 Aug 2021 13:44:41 GMT"], "Api-Version": ["1.41"]}, "status": 200}
I tried the flush_interval -1 command (as shown in the config file). I’ve also tried requesting the URL with curl directly (instead of just using the Docker CLI), with the same outcome (URL was curl http://127.0.0.1:2379/v1.41/events?filters=%7B%22type%22%3A%7B%22container%22%3Atrue%7D%7D)
