I receive a 502 error when connecting to one of my reverse proxy endpoints via caddy. I two configured, one works, one does not. I am attempting to connect to a Splunk instance, and Splunk is configured for http only. Referring to my Caddyfile, the photos reverse proxy works, but splunk does not. I am using macvlan networking for Splunk but the bridge networking for my photos endpoint. Everything is running in Docker on the same physical host.
curl -vL splunk.reimerfamily.net
* Trying 70.169.10.9:80...
* Connected to splunk.reimerfamily.net (70.169.10.9) port 80 (#0)
> GET / HTTP/1.1
> Host: splunk.reimerfamily.net
> User-Agent: curl/7.88.1
< Connection: close
< Location: https://splunk.reimerfamily.net/
< Server: Caddy
< Date: Tue, 17 Sep 2024 11:22:50 GMT
< Content-Length: 0
* Closing connection 0
* Issue another request to this URL: 'https://splunk.reimerfamily.net/'
* Trying 70.169.10.9:443...
* Connected to splunk.reimerfamily.net (70.169.10.9) port 443 (#1)
* ALPN: offers h2,http/1.1
* CApath: /etc/ssl/certs
* ALPN: server accepted h2
* subject: CN=splunk.reimerfamily.net
* start date: Sep 13 09:13:29 2024 GMT
* expire date: Dec 12 09:13:28 2024 GMT
* subjectAltName: host "splunk.reimerfamily.net" matched cert's "splunk.reimerfamily.net"
* issuer: C=US; O=Let's Encrypt; CN=E5
* SSL certificate verify ok.
* using HTTP/2
* h2h3 [:method: GET]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: splunk.reimerfamily.net]
* h2h3 [user-agent: curl/7.88.1]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x55a6e7cedce0)
> GET / HTTP/2
> accept: */*
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Tue, 17 Sep 2024 11:22:53 GMT
* Connection #1 to host splunk.reimerfamily.net left intact
{"level":"debug","ts":1726572542.0957484,"logger":"events","msg":"event","name":"tls_get_certificate","id":"38beca5d-50b9-4198-824d-32003480ea40","origin":"tls","data":{"client_hello":{"CipherSuites":[23130,4865,4866,4867,49196,49195,52393,49200,49199,52392,49162,49161,49172,49171,157,156,53,47,49160,49170,10],"ServerName":"splunk.reimerfamily.net","SupportedCurves":[60138,29,23,24,25],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,515,2053,2053,1281,2054,1537,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[23130,772,771,770,769],"RemoteAddr":{"IP":"192.168.6.252","Port":63747,"Zone":""},"LocalAddr":{"IP":"172.18.0.2","Port":443,"Zone":""}}}}
{"level":"debug","ts":1726572542.0957925,"logger":"tls.handshake","msg":"choosing certificate","identifier":"splunk.reimerfamily.net","num_choices":1}
{"level":"debug","ts":1726572542.0958216,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"splunk.reimerfamily.net","subjects":["splunk.reimerfamily.net"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"efd0dfe09d0d851f869d35ef6d70edcbb43ccc9474eb1cc3954e27df0f077fa5"}
{"level":"debug","ts":1726572542.0958354,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"192.168.6.252","remote_port":"63747","subjects":["splunk.reimerfamily.net"],"managed":true,"expiration":1733994809,"hash":"efd0dfe09d0d851f869d35ef6d70edcbb43ccc9474eb1cc3954e27df0f077fa5"}
{"level":"debug","ts":1726572542.103056,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.7.70:8000","total_upstreams":1}
{"level":"debug","ts":1726572545.1046853,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.7.70:8000","duration":3.001523407,"request":{"remote_ip":"192.168.6.252","remote_port":"63747","client_ip":"192.168.6.252","proto":"HTTP/2.0","method":"GET","host":"splunk.reimerfamily.net","uri":"/","headers":{"Sec-Fetch-Dest":["document"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.0 Safari/605.1.15"],"Priority":["u=0, i"],"Accept-Language":["en-US,en;q=0.9"],"Accept-Encoding":["gzip, deflate, br"],"X-Forwarded-For":["192.168.6.252"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["splunk.reimerfamily.net"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"Sec-Fetch-Site":["none"],"Sec-Fetch-Mode":["navigate"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"splunk.reimerfamily.net"}},"error":"dial tcp 192.168.7.70:8000: i/o timeout"}
{"level":"error","ts":1726572545.1048007,"logger":"http.log.error","msg":"dial tcp 192.168.7.70:8000: i/o timeout","request":{"remote_ip":"192.168.6.252","remote_port":"63747","client_ip":"192.168.6.252","proto":"HTTP/2.0","method":"GET","host":"splunk.reimerfamily.net","uri":"/","headers":{"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"Sec-Fetch-Site":["none"],"Sec-Fetch-Mode":["navigate"],"Accept-Language":["en-US,en;q=0.9"],"Priority":["u=0, i"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Dest":["document"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.0 Safari/605.1.15"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"splunk.reimerfamily.net"}},"duration":3.001773372,"status":502,"err_id":"ecud2gef3","err_trace":"reverseproxy.statusError (reverseproxy.go:1269)"}
Docker compose
Debian bookworm running docker engine version 27.2.1 and docker compose version 2.29.2.
docker compose up -d
image: caddy:latest
cap_add:
- NET_ADMIN
- /reimerfamdata/docks/caddy/Caddyfile:/etc/caddy/Caddyfile
- /reimerfamdata/docks/caddy/data:/data
- /reimerfamdata/docks/caddy/config:/config
photos.reimerfamily.net {
reverse_proxy 192.168.7.5:2342
splunk.reimerfamily.net {
reverse_proxy http://192.168.7.70:8000
