Caddy 2.0.0
Ubuntu 18.04 using the default systemd unit file that comes with the .deb package provided on the GH release page
Ubuntu 18.04 using systemd
systemd unit file from GH release deb file
See below
I have been trying all day to migrate my Caddyfile at work to the new Caddyfile format.
This config below, the old one, works flawlessly using Caddy 1 but it doesn’t work on Caddy 2.
The issue I am currently having is the following:
This piece of Caddyfile configuration has worked flawlessly.
Here I am running a ttyd daemon and have Caddy act as a reverse proxy in front of it.
http://10.0.0.2:4444/share {
proxy / localhost:7681 {
health_check /
health_check_interval 5s
websocket
# To get the custom error page displayed correctly I have to make these exception
except 500.html styles.css favicon.ico
now when I adapt this to the new Caddyfile syntax this looks like this
reverse_proxy {
to localhost:7681
{"level":"error","ts":1588698482.697211,"logger":"http.log.access.log0","msg":"handled request","request":{"method":"GET","uri":"/share","proto":"HTTP/1.1","remote_addr":"127.0.0.1:54358","host":"10.0.0.2:4444","headers":{"Accept-Language":["en-US,de-DE;q=0.7,en;q=0.3"]
,"Accept-Encoding":["gzip, deflate"],"Upgrade-Insecure-Requests":["1"],"Cache-Control":["no-cache"],"User-Agent":["Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:75.0) Gecko/20100101 Firefox/75.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/
*;q=0.8"],"Dnt":["1"],"Connection":["keep-alive"],"Pragma":["no-cache"]}},"common_log":"127.0.0.1 - - [05/May/2020:19:08:02 +0200] \"GET /share HTTP/1.1\" 404 38","duration":0.000467393,"size":38,"status":404,"resp_headers":{"Server":["Caddy","ttyd/1.6.0-29507ed (libwebso
ckets/2.0.3)"],"Content-Type":["text/html"],"Content-Length":["38"]}}
{"level":"info","ts":1588698482.7877393,"logger":"http.log.access.log0","msg":"handled request","request":{"method":"GET","uri":"/favicon.ico","proto":"HTTP/1.1","remote_addr":"127.0.0.1:54358","host":"10.0.0.2:4444","headers":{"User-Agent":["Mozilla/5.0 (X11; Ubuntu; L
inux x86_64; rv:75.0) Gecko/20100101 Firefox/75.0"],"Accept":["image/webp,*/*"],"Accept-Language":["en-US,de-DE;q=0.7,en;q=0.3"],"Connection":["keep-alive"],"Pragma":["no-cache"],"Accept-Encoding":["gzip, deflate"],"Dnt":["1"],"Cache-Control":["no-cache"]}},"common_log":"
127.0.0.1 - - [05/May/2020:19:08:02 +0200] \"GET /favicon.ico HTTP/1.1\" 0 0","duration":0.000007586,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
This is the ttyd output:
$ ttyd -i lo -T screen-256color tmux attach -t 2
[2020/05/05 19:06:46:6493] NOTICE: ttyd 1.6.0-29507ed (libwebsockets 2.0.3)
[2020/05/05 19:06:46:6493] NOTICE: tty configuration:
[2020/05/05 19:06:46:6493] NOTICE: start command: tmux attach -t 2
[2020/05/05 19:06:46:6493] NOTICE: close signal: SIGHUP (1)
[2020/05/05 19:06:46:6493] NOTICE: terminal type: screen-256color
[2020/05/05 19:06:46:6493] NOTICE: Initial logging level 7
[2020/05/05 19:06:46:6493] NOTICE: Libwebsockets version: 2.0.3 unknown-build-hash
[2020/05/05 19:06:46:6494] NOTICE: IPV6 not compiled in
[2020/05/05 19:06:46:6494] NOTICE: libev support compiled in but disabled
[2020/05/05 19:06:46:6494] NOTICE: libuv support compiled in and enabled
[2020/05/05 19:06:46:6494] NOTICE: Threads: 1 each 1024 fds
[2020/05/05 19:06:46:6494] NOTICE: mem: platform fd map: 8192 bytes
[2020/05/05 19:06:46:6494] NOTICE: Compiled with OpenSSL support
[2020/05/05 19:06:46:6494] NOTICE: SSL disabled: no LWS_SERVER_OPTION_DO_SSL_GLOBAL_INIT
[2020/05/05 19:06:46:6494] NOTICE: Creating Vhost 'default' port 7681, 2 protocols
[2020/05/05 19:06:46:6496] NOTICE: Listening on port 7681
[2020/05/05 19:06:46:6496] NOTICE: mem: per-conn: 920 bytes + protocol rx buf
[2020/05/05 19:06:46:6496] NOTICE: canonical_hostname = LC0013
[2020/05/05 19:06:46:6496] NOTICE: Listening on port: 7681
[2020/05/05 19:06:46:6496] NOTICE: Using foreign event loop...
[2020/05/05 19:06:46:6598] NOTICE: lws_protocol_init
[2020/05/05 19:07:32:9590] NOTICE: HTTP /share - 127.0.0.1
[2020/05/05 19:08:02:6970] NOTICE: HTTP /share - 127.0.0.1
^C[2020/05/05 19:09:32:0065] NOTICE: received signal: SIGINT (2), exiting...
The problem seems to be that the reverse_proxy module passes the /share URI as well; which is not desired as ttyd does not server anything at /share.
When I open the URL I just get a 404.
Anybody have any ideas or clues?
see above
Omitting the /share path makes the reverse proxy work.
The port 4444 is temporary and I might want to remove it as well. I actually have it some places without it.
Using this software that I want to make accessible through the reverse proxy GitHub - tsl0922/ttyd: Share your terminal over the web
