Return another response without redirecting
I need to return the response of https://zaps.birb.it/lnurl from https://birb.it/.well-known/lnurlp/ingwie2 since a redirect seems to be causing issues for some clients.
I tried reverse_proxy https://zaps.birb.it { rewrite /lnurl }, but to no avail.
Each time I do that, I get a 404 error in cURL and the logs show no error - so I suspect that I have misunderstood how reverse_proxy.rewrite works, or it’s something else.
Sadly none.
I updated this before writing this issue and verified the issue still persists.
I use XCaddy to build the latest version with plugins. Full script:
#!/bin/bash
# Run after apt upgrade caddy
xcaddy build \
  --with github.com/gamalan/caddy-tlsredis \
  --output /usr/local/bin/caddy
Ubuntu 22.04 LTS, arm64
I use a SystemD unit (systemctl start/stop/reload caddy) derived from the default one - it just uses a custom path to work with xcaddy.
Type=notify
ExecStart=/usr/local/bin/caddy run --environ --config /srv/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /srv/Caddyfile --force
# I excluded the other domains.
# zaps.birb.it is just a simple reverse_proxy block providing https://github.com/elsirion/clnurl
birb.it {
  # This one works; mostly.
  handle /.well-known/lnurlp/ingwie {
    header Access-Control-Allow-Origin *
    redir https://zaps.birb.it/lnurl
  # This one does not.
  handle /.well-known/lnurlp/ingwie2 {
    #rewrite * /lnurl
    reverse_proxy * https://zaps.birb.it {
      rewrite /lnurl
  # Irrelevant, but keeping it here for completion
  handle /.well-known/* {
    uri strip_prefix /.well-known
    file_server {
      root /srv/birb.it/well-known
  # Another service
    reverse_proxy localhost:8080
The service provided by zaps.birb.it: GitHub - elsirion/clnurl: Playing around with CLN and LNURL
You probably need to set the Host header since you’re proxying over HTTPS reverse_proxy (Caddyfile directive) — Caddy Documentation
Please show that. Enable the debug global option and show your logs. Show what you get from curl -v.
