servatj
(Josep Servat)
October 29, 2021, 5:26pm
1
Hi all,
When I stop caddy I get all the time that the admin por is not available, and I 'm not sure if its reloading the config since the admin API is down.
A second problem I have is that I can’t find any example about create a reverse proxy with different ports on the same domain.
is it like this
my_domain {
reverse_proxy :exposed port localhost:port
reverse_proxy :otherexposed port localhost:port2
Do I have to do this with handlers only ?
Thanks in advance.
Josep
Please fill out the help topic template.
Click on “New Topic”, make sure the “Help” category is chosen, then copy the template that’s filled in the text box, and fill it out as a reply in this topic.
servatj
(Josep Servat)
October 29, 2021, 7:57pm
4
version 2.4.5
caddy run or caddy start
Linux 20.4
my_domain {
How can I run a reverse proxy that maps multiple ports on the same domain ?
No error not working.
I tried with multiple configs no one worked
If I understand what you’re saying (your Caddyfile example is confusing because you’re not actually using numbers), then you might want something like this?
example.com:8000 {
reverse_proxy localhost:8001
example.com:9000 {
reverse_proxy localhost:9001
But doing this, you’re running on non-standard ports. What you should do instead is use a subdomain for each service, like this:
first.example.com {
second.example.com {
This way, you’ll be using the standard HTTPS port 443, and the routing will be by subdomain.
system
(system)
Closed
November 28, 2021, 5:27pm
6
