When trying to get a certificate via acme from LE using dns challenge, caddy queries localhost instead of the DNS set in /etc/resolv.conf. As localhost has no process listening on port 53, this fails.
I tried to force the use of cgo using export GODEBUG=netdns=cgo+1
but got
go package net: cgo resolver not supported; using Go's DNS resolver
I then tried to get debug info from the go resolver using export GODEBUG=netdns=go+1
. But all I got was go package net: GODEBUG setting forcing use of Go's resolver
and no other debug info.
2024/05/02 15:07:44.587 INFO using adjacent Caddyfile
2024/05/02 15:07:44.589 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2024/05/02 15:07:44.589 INFO http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2024/05/02 15:07:44.590 INFO http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2024/05/02 15:07:44.590 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000381380"}
2024/05/02 15:07:44.590 INFO http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2024/05/02 15:07:44.590 INFO http enabling HTTP/3 listener {"addr": ":443"}
2024/05/02 15:07:44.590 INFO failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details.
2024/05/02 15:07:44.590 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2024/05/02 15:07:44.590 INFO http enabling automatic TLS certificate management {"domains": ["server.tld.com"]}
2024/05/02 15:07:44.590 INFO autosaved config (load with --resume flag) {"file": "/root/.config/caddy/autosave.json"}
2024/05/02 15:07:44.590 INFO serving initial configuration
2024/05/02 15:07:44.591 INFO tls.obtain acquiring lock {"identifier": "server.tld.com"}
2024/05/02 15:07:44.592 WARN tls storage cleaning happened too recently; skipping for now {"storage": "FileStorage:/root/.local/share/caddy", "instance": "1ccda99d-cd0c-42e2-8eac-dfb0144bfcda", "try_again": "2024/05/03 15:07:44.592", "try_again_in": 86399.999999359}
2024/05/02 15:07:44.592 INFO tls finished cleaning storage units
2024/05/02 15:07:44.593 INFO tls.obtain lock acquired {"identifier": "server.tld.com"}
2024/05/02 15:07:44.593 INFO tls.obtain obtaining certificate {"identifier": "server.tld.com"}
2024/05/02 15:07:44.593 INFO tls.issuance.acme waiting on internal rate limiter {"identifiers": ["server.tld.com"], "ca": "https://acme-staging-v02.api.letsencrypt.org/directory", "account": "letsencrypt@tld.com"}
2024/05/02 15:07:44.593 INFO tls.issuance.acme done waiting on internal rate limiter {"identifiers": ["server.tld.com"], "ca": "https://acme-staging-v02.api.letsencrypt.org/directory", "account": "letsencrypt@tld.com"}
2024/05/02 15:07:45.588 INFO tls.issuance.acme.acme_client trying to solve challenge {"identifier": "server.tld.com", "challenge_type": "dns-01", "ca": "https://acme-staging-v02.api.letsencrypt.org/directory"}
2024/05/02 15:07:57.904 ERROR tls.issuance.acme.acme_client cleaning up solver {"identifier": "server.tld.com", "challenge_type": "dns-01", "error": "deleting temporary record for name \"_acme-challenge.server.tld.com\" in zone \"tld.com.\": (2200) Authentication error. Reason: (INVALID) The confirmation code is invalid."}
-->2024/05/02 15:07:58.080 ERROR tls.obtain could not get certificate from issuer {"identifier": "server.tld.com", "issuer": "acme-staging-v02.api.letsencrypt.org-directory", "error": "[server.tld.com] solving challenges: waiting for solver certmagic.solverWrapper to be ready: checking DNS propagation of \"_acme-challenge.server.tld.com\": read udp 127.0.0.1:52185->127.0.0.1:53: read: connection refused (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/146529714/16276960954) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
2024/05/02 15:07:58.080 ERROR tls.obtain will retry {"error": "[server.tld.com] Obtain: [server.tld.com] solving challenges: waiting for solver certmagic.solverWrapper to be ready: checking DNS propagation of \"_acme-challenge.server.tld.com\": read udp 127.0.0.1:52185->127.0.0.1:53: read: connection refused (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/146529714/16276960954) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)", "attempt": 1, "retrying_in": 60, "elapsed": 13.487398367, "max_duration": 2592000}
^C2024/05/02 15:08:00.019 INFO shutting down {"signal": "SIGINT"}
2024/05/02 15:08:00.019 WARN exiting; byeee!! 👋 {"signal": "SIGINT"}
2024/05/02 15:08:00.019 INFO http servers shutting down with eternal grace period
2024/05/02 15:08:00.020 INFO tls.obtain releasing lock {"identifier": "server.tld.com"}
2024/05/02 15:08:00.020 ERROR tls.obtain unable to unlock {"identifier": "server.tld.com", "lock_key": "issue_cert_server.tld.com", "error": "remove /root/.local/share/caddy/locks/issue_cert_server.tld.com.lock: no such file or directory"}
2024/05/02 15:08:00.020 ERROR tls job failed {"error": "server.tld.com: obtaining certificate: context canceled"}
2024/05/02 15:08:00.020 INFO admin stopped previous server {"address": "localhost:2019"}
2024/05/02 15:08:00.020 INFO shutdown complete {"signal": "SIGINT", "exit_code": 0}
I marked the line showing the error with arrow, here’s a copy. Note the
v2.7.6
I selected the inwx plugin and downloaded the caddy binary from Download Caddy.
Debian 12.5, 64bit, no docker
Still evaluating caddy, no unit file.
email letsencrypt@tld.com
acme_dns inwx {
username redacted
password redacted
shared_secret redacted
server.tld.com:443 {
reverse_proxy :8080
